Pitts S1-S by EMHW
#901
Wire keepers....
http://www.amainhobbies.com/product_...FawRMwoddDAAqA
#905
I bought some mini wire clips at Radio Shack this weekend that are only about 1/4" tall with double sided tape on the bottom that seem to work pretty good for my 182. The had a small hole if you wanted to use a screw. They were available in store $3 for 10.
Here is a link: http://www.radioshack.com/product/in...tent=CT2032237
#906
Robert, is there enough slack in those wires to run them through a 1/2" model rocket tube? The tube would be light and would be an effective way to run your wires hidden from view.
#907
Ok gentlemen here is what I did or should I say used, I don't know what this stuff is called. This gives a means for getting to the wiring if ever there becomes a need. All of the wiring has been secured with the exception of the wing incoming wires, they will be secured upon final assembly. I appreciate every ones advice on how to get it done, and the plastic stuff I used may have been mentioned. Thanks.
#908
The making and fitting of the fuse panels has begun.
Most of them are pretty simple but the one on each side that encase the cabanes are a bit of work. Once they are all fitted then I will drill and place the screws per the scale drawings.
#911
Thanks Flyer, it is starting to resemble something. I am waiting on the glue to dry in the screw drilling hole guide. Just to give a reference to the size of this thing here is me and one from Monster Planes.
#913
Holy crap. That's one sweet ride your gonna have there ace. Can't say I'm not a little bit envious. Someday...someday.beautiful work so far. I'm really enjoying watching it come together.
#914
#916
Well, I don't think I'm that short so it must be that big.
I came back early this trip, just did not feel up to clearing another day. Probably won't go back until after the first of the new year.
So I got to work on the panels, the first set was made with construction paper, the second with the metal, and with some fine tuning the third set will be final. Here is three panels I have done today so far. Believe it or not it takes about an hour to do each one, cut the shape from the roll, trim to a close fit, pre drill holes, screw in place, mark perimeter for fine tuning trim, slide wing up to aluminum and mark, remove wing and sheet, trim for wing and fine tune edges, screw sheet back in place, and go to next panel.
#919
Thanks Guys. It is a real PITA to do well, I have been fighting with the one that surrounds the cockpit since my last post yesterday. As soon as I get it finished up I'll post the panels completed.
And I am quite aware that for those that followed the little Pitts, this is a rerun.
#921
Finally!!! The panels are installed, short of a few screws that should be here the first of the week. Actually all the screws get replaced with Phillips head. Next is to glass the inside of the piece surrounding the cockpit. That gives it a good deal of support which is needed because of the canopy rails and reaching in to turn switches off. Also have to get a larger coping, the one laying on it is way too small.
#925
Well if it makes you guys feel better it may not get painted, not as metal anyways. It did not conform as well as I would like so I am thinking of using those as templates to make some glass panels out of 5oz glass. Of course being that I moved all the electronics to the rear access is not longer needed so I could also sheet it. I will wait and see how the cowl fit's with the front edge of the metal first being that is the area of concern. I am currently finishing up the top wing, well, fine tuning that is. And then I will place the engine and cowl and see how the cowl fits.
