Sopwith Pup Help
Hi
I am coming to the end of building a 1/8th scale Sopwith pup and now I am at the point were I need to choose what motor and propeller I need to pull this thing. I believe this related to the scale aircraft but am not sure and I apologies profusely if I have posted this in the wrong place. So anyway here are some of the details that I believe will help you help me decide on what electric motor and prop I need:
Rough weight: 1.5 kg
Room (height) in cowl for motor: 40mm
Reason in which the weight is rough, because I weighed it without the wheels and electronics which was 1.1kg. Finally I thank you for reading this and hope you can help me.
Ben
Ben
I'm thinking of making electric now, I don't think my plan is from DB Sport but it is very similar these are the parts I'm thinking of using:
Motor: http://www.hobbyking.co.uk/hobbyking...50Kv_600W.html
ESC: http://www.hobbyking.co.uk/hobbyking...C_4A_UBEC.html
Propeller: http://www.hobbyking.co.uk/hobbyking..._1pc_bag_.html
Battery: http://www.hobbyking.co.uk/hobbyking...Lipo_Pack.html
So these are based of the recommended electronics on the DB Sport website what do you think is there are problem using all these electronics together?
Thanks Again,
Ben
Thanks Again,
Ben
That all seems like a lot of power for a 1/8 scale Pup.
Enough to power a 1/6 Scale BUSA Pup I would have said.
And you won't get very long flight times from a 2100 MAh pack like that I would have thought.
Others may know more.
Cheers,
Hugh
Cheers,
Hugh
