Albatros D.III Build along
#676
SC
RE: Albatros D.III Build along
Hi all,
The FA SE5a is not as scale as the Albatross although they are both pretty much off scale. I am sure you will have fun building it. In the Kit Builder section, a couple year back someone post a very detailed built of the kit. I was very impressed of how detailed the write up is. Sadly, the builder did not complete the kit and it has been at least a year since the last post. I finally got the batteries for my Albatros and it will fly soon. I am using the DX7 for it. DP
#677
SC
ORIGINAL: Prop Nut
Hey DP, what was the final weight on your DIII?
The dry weight without the batteries is 11 lbs. I have not checked the final weight yet. DP
#678
KS
Ok guys, I've noticed this thread has kinda slowed down...LOL! Everyone is waiting for Dai's maiden flight but until then I have a question. Since these Albatros's are tail heavy has anyone thought about powder coating the spinner on this plane to add nose weight? I'm thinking if you powder coat the inside and outside it could really help. Might not have to add so much lead to the nose. I was all so thinking the powder coating would be tough enough not to chip and you can get coatings in various colors these days.
#680
TX
Dai Phan said a long time ago in this thread that the Albatros might be a hanger queen, I am beginning to think that he is a prophet as well as an amazing model airplane builder.
#681
SC
The plane had been flown but crashed on the first flight. As the result, I cannot bear to see the remains... I can't even think about RC planes at all without bringing back the painful memories.... I have ebayed all my planes and now am taking on stamp collecting. See my new "no panic attack easy going" hobby here...
http://abqtrib.com/news/2007/feb/15/...oses-laughter/
Actually, it will be very soon of the maiden and I assure you it ain't gonna to be a hangar queen. The tail you should not sheet it and just cover over the open structure like someone on RC Groups did. DP
#685
VA
Thats a great account DP, you have an amazing history. You are a true American success story and its an honor to know you. (At least we feel like we know you)
ZZ.
ZZ.
#686
SC
I am so bump out guys... The DX7 I ordered on RCU got sent to the wrong address (not seller fault) so instead of maiden this Saturday, it will have to wait. $%^&$^&$&$***^%43%#$#%#% !!!! DP
#690
SC
ORIGINAL: Hot Rod Todd
I know what it's like to wait for the maiden flight. Since I live in Iowa, I have to wait for spring to fly my completed Kawasaki Ki-61.
#693
SC
The Tony is from Don Smith plans, but I found a fiberglass fuse to use. The cat is a purebread breed called a Bengal, and it knows better than to scratch my planes!
#694
SC
#695
SC
For those who have flown the Albatross, what is the proper CG for this plane and are there anything I should watch out for on the maiden? Thanks! DP
#696
The Recommended CG in the Plans is OK, I think it ends up on the spar. The problem comes with setting it. The top wing is so high that you may believe you have it balanced with the tail a bit low. You find out that you can be way off and the tail will sag just a bit. Make sure the tail is level or above level a little with the CG on the spar, and you should be fine.
Good luck on your flight, hope it all turns out well! Here are a couple of in flight photos to get you in the right mindset.
#697
SC
#700
SC
Last night I look at the battery set up with my electric Guru friend Gary and the whole thing looks very "scary". Two big Lipos stuck half way through the fireway making it looks like roadside IDEs. I am quite sure if this thing flies away, the cops will think it is an RC bomb! I will post pictures when it is ready to fly. DP
