The Pup Has Begun!
RE: The Pup Has Begun!
Chevelle, you could clear coat the entire plane after your markings were applied. That would seal the entire plane including the seams. I have chosen Nelson's clear to put on my SE5a. From what I have learned/read Nelson's water base clear is good stuff. You can do a search here on RCU about clear over coats and read what others like as well. Your plane is looking real good!! Thanks for posting.. BobH.
NY,
I'm sooooo jealous, your Pup looks amazing. I'm considering either the Pup or the Neiport for next winter's project. Check out Aces of Iron pilots.If you can afford the bucks, treat yourself. I have one in my 1/5th Waco.
Jeff
Jeff
VERY close now!!! Just have to wire up the emergency cutoff switch and then I will fire this Pup(py) up!
Hope to be able to taxi it about this weekend. Probably fly it the next weekend!
#31
The Pup had it's taxi tests today. Much better ground handling that I thought. There is no tail wheel. Just a free-castoring skid. I had no trouble getting it to move right or left.
Takes a bit of getting used to. Taxiing straight requires right rudder as expected and after a few runs, I could get it to run pretty straight and true.
The tail comes up pretty fast. A couple of times the front wheels "got light" but I didn't take off. Good thing too. It was pretty gusty for a maiden flight and I may not have done a proper job securing the elevator hinges. (Oops.)
A few minor adjustments and up we go. Next trip to the field for sure!
#35
Oh yeah. Sorry about that. The thread kind of died out so I never capped it off here. (I did in the Giant forum though. Thanks for the cross link Bruno.)
Here is a movie made from three flights on the day of the maiden. A week or so after the movie was made, I added the pilot, painted the wheels, and added some more detail on the gun.
Thanks for your interest.
Chevelle
MOVIE>>> [link=http://www.wings-of-valor.net/uploads/PupFlight1_256.wmv]"The Pup's Maiden Flight"[/link]
Chevelle
#36
IN
I like the red stripes you put on the edge of the fuse top. Was this paint?
Also, the insignia on the side was nice. Was this a water slide or something else?
Stall,
Nope. Just strips of white and then red monocote.
I am a member of the "Black Adders", an online WWI squadron that flies "Red Baron 3D". That is our emblem. I printed it on clear label stock that you can get at any office supply company (Office Max, Staples, etc.) It is has faded a bit. I think I will print another set using the color laser printer at work. I wouldn't use that technique for true scale competitions but for just fun and games, it works just fine.
Chevelle
Chevelle
#40
FL
Chevelle,
Great looking Pup! What can you tell me about the isolation mount you used for your gas engine. Is it commerically available or did you come up with it yourself? I'm converting a Featherlite Poulan gas engine to go on the front of a BUSA Eindecker, and was curious about how you mounted your engine to the firewall. Your installation looks very impressive.
Brian C.
Brian C.
#41
Thanks Brian.
The mount is a product made by Great Planes. I actually ended up with it accidentally. I initially purchased a US Engine from a club-mate and he included the mount. I decided to move to the Zenoah instead but I had already drilled for the mount. It seems to work just fine but it extended the engine out a bit. That did cause a problem. I had several options but the one that I chose was to take advantage of the aluminum that I would be adding. I made a ring out of scrap MDF and attached it to the firewall. (You can see part of it in the picture.) That moved the cowl mounting blocks out which of course moved the cowl out too. When I made the aluminum sheets, I just made them a bit longer so they covered the extenstion. Seems to work just fine.
