 BEGINNER QUESTION >
BEGINNER QUESTION
BEGINNER QUESTION
Old 04-10-2004 | 09:47 PM
Default BEGINNER QUESTION
hI hi i WAS WONDERING WHAT WOULD BE A GOOD FIRST TIME SCALE PROJECT
Old 04-10-2004 | 11:25 PM
abufletcher's Avatar
Default RE: BEGINNER QUESTION
I'd say you have to narrow this down somewhat to get a helpful reply. For example, what sort of prior building/modelling/flying experience do you have? What sort of skills would you like to learn? If you like the WWII birds you might want to pick a subject that has the usual features, such as rivets, panel lines, etc. and pick a model that has these in an easy way. I chose the Eindecker partly because it is boxy and therefore a pretty straight-forward build for someone like me. Also I wanted to learn how to work with SolarTex (vs. monokote), how to simulate aluminum cowls and side panel, how to do a pull-pull cable system, stitching, rigging and all the other things typical of WWI planes. I don't know how good my Eindecker will look (or fly!) when I'm done but I'll have learned a ton about scale building and that'll mean a better second scale effort.
Best of luck with whatever project you end up choosing.
Old 04-11-2004 | 09:38 AM
I recomend a great planes cherokee .40 semi-scale as it is a little more chalenging in flight charistics. If your lucky you might be able to find one at a trade show near you. or if you want look at the great planes website pick out a plane you think it's scale and start from there and build yourself up. that's how i did i miss that cherokee should have not sold it!!!!
Old 04-11-2004 | 03:25 PM
If a warbird is your cup of tea. Try one of the Skyshark kits. I hear that they are fantastic kits.
Mark Shuman
