Piano Hinges
Banned
I am looking for a method of simulating piano hinges. I have done this in the past for short hinges, but the ones I need now are 8" long, times 4. 2 on each side of the cowling. I had found some at Micro Mark, but when I went back for more they had discontinued the item.
Les
Les
Les, to simulate piano hinges (I didn't know that's what they were called) on one of the panels on my EIII I took 1/16 styrene covered wire and rolled a single-edge razor back and forth across at regular intervals. This creates the space between the hinge sections. Then I painted the whole thing aluminum to match the panel and then just glued it along one edge. The effect is good but I suppose probably not as good as using the real thing -- if they fit.
Banned
Thanks Abu. I will have to try that. Most of the ones that I have simulated have been functional, but not all of them. I like the idea. On this plane, only two of them need to be functional, and maybe only one.
Les
Les
