 large pusher prop >
large pusher prop
large pusher prop
Old 09-18-2004 | 06:38 PM
My Feedback: (23)
Default large pusher prop
Does any one know where I can get my hands on a large pusher prop? I am looking for a 22X6-10.
Any Help is Appreciated
Old 09-19-2004 | 09:26 AM
Default Zinger has these...
Dear Sticks-RCU:
The PIPE here again....and at http://www.zingerpropeller.com/Pusher.htm you SHOULD be able to find a prop in Zinger's PUSHER lineup that you could use...!
They don't YET have a "progressive pitch" prop, such as a 22 x 6-10, that you mentioned, in their pusher lineup...but they DO have 22 x 8 through 22 x 16 props, in two inch pitch increments, that should supply you with one, of "conventional pitch" setup, which could be of use to you!
APC's largest pusher prop is a 20 x 10 in their lineup (at http://www.apcprop.com/cgi-bin/store...c=6a&product=+ )...and I don't know of ANYONE else that makes a pusher prop of 22 inch diameter (but I COULD be wrong on that one)...but hopefully, among the Zinger pushers available, you'll find the one you CAN use for your needs!
Yours Sincerely,
The PIPE!
Old 09-19-2004 | 02:29 PM
Idigbo's Avatar
Default RE: Zinger has these...
Hello there from the UK. A guy over here makes props, Eric Thomas of EAT Props. He made a 30"x10" and a 30"x 14" pusher for me and they work beautifully. He does post worldwide. If you want his contact details, I'll root 'em out. Hope this helps, Ian.
