Weathering Question >
Weathering Question
Weathering Question
Old 08-22-2002 | 05:00 PM
mr_matt's Avatar
My Feedback: (10)
Default Weathering Question
I am building my first scale plane, and I needed some tips on very simple techniques to weather the plane, especially the molded in panel lines.
My paint system is PPG, with a DBC base and Flex and Flat 2060 clear coat.
Thanks in advance for any help.
Old 08-22-2002 | 07:16 PM
My Feedback: (60)
I like to use a dark gray or brown wash to highlight my panel lines. I have even used a fine tip black pen which is drawn down into the panel line and then use a rag with alchohol to wipe most of it away. You just want to leave a hint of dark down in the line to make it stand out a bit. Less is more when it comes to weathering so be subtle. Good luck.
PS- on a dark airplane you may consider a wash of a lighter color
Old 08-22-2002 | 07:35 PM
My Feedback: (8)
Stop by these websites:
http://www.hyperscale.com
http://www.internetmodeler.com
http://www.modelingmadness.com
They are dedicated to plastic scale models, but these guys are masters of weathering and a lot of good tips can be found.
Old 08-22-2002 | 11:15 PM
mr_matt's Avatar
My Feedback: (10)
Default thanks for the tips,
subtle is the key!
