Wooden props don't work on 4 stroke engines - right?
MI
RE: Wooden props don't work on 4 stroke engines - right?
Seagull:
I think you have an answer. You may use a wood prop.
Set your mixture with a tachometer instead of by ear. A lean mixture leads to backfires. Secure the prop correctly and re-check the prop nut regularly. Think safety.
