Top Flite Staggerwing??
#51
My Feedback: (18)
LA
FYI - Tower has finally added a picture to the product listing and added some specs:
REQUIRES: Engine: 1.60 cu in (25cc) 2-stroke OR 1.60 cu in (25cc) 4-stroke Muffler: Radio: 6-channel minimum, 8 or 9 channel required for retracts Servos: Six 54oz-in and one 30oz-in, Seven 54oz-in and two 30oz-in servos if retracts are installed 6" (152mm) Servo Extensions: Two for flaps 12" (305mm) Servo Extensions: Two for ailerons Y-Harness: Two Flight Battery: 1000mAh or greater Misc. Items: Glow plug, 1/2" foam rubber padding, medium fuel tubing, fuel filter, propeller, building and field equipment.
SPECS: Wingspan: 72.5" (1840mm) Wing Area: 1525 sq in (97.6sq dm) Weight: 17 - 19lb (7710 - 8620g) Wing Loading: 26 - 28oz/sq ft (80 - 90g/sq dm) Length: 63.5" (1610mm)
#52
VA
Thanks, Chris. I'm headed out to Toledo next week and imagine I'll see it there. I have it on backorder, so guess I'll sell my Ziroli Staggerwing plans and Precision Cut kit I had cut. Any takers?
Al
Al
