 Interesting stats >
Interesting stats
Interesting stats
Old 02-11-2006 | 09:24 PM
-JC-'s Avatar
My Feedback: (26)
Default Interesting stats
"One Second in the Life of a Racer" by Tom Fey
The Unlimiteds go flashing through the racecourse, engines howling, air shearing, heat waves streaming. Four hundred eighty miles an hour is 8 miles a minute and the elite racers take about 70 seconds to cover the 9.1-mile Reno course. If you could take a souped P-51 racer flying the circuit at Reno, slow time down, and examine just one second, what would you find?
In that one second, the V-12 Rolls-Royce Merlin engine would have gone through 60 revolutions, with each of the 48 valves slamming open and closed 30 times. The twenty-four spark plugs have fired 720 times. Each piston has traveled a total of 60 feet in linear distance at an average speed of 41 miles per hour, with the direction of movement reversing 180 degrees after every 6 inches. Three hundred and sixty power pulses have been transmitted to the crankshaft, making 360 sonic booms as the exhaust gas is expelled from the cylinder with a velocity exceeding the speed of sound.
The water pump impeller has spun 90 revolutions, sending 4 gallons of coolant surging through the engine and radiators. The oil pumps have forced 47 fluid ounces, roughly one-third gallon, of oil through the engine, oil cooler, and oil tank, scavenging heat and lubricating the flailing machinery. Perhaps 1/8 fluid ounce of engine oil has been either
combusted or blown overboard via the crankcase breather tube.
The supercharger rotor has completed 348 revolutions, its rim spinning at Mach 1, forcing 4.2 pounds or 55 ft # of ambient air into the combustion chambers under 3 atmospheres of boost pressure. Around 9 fluid ounces of high-octane aviation fuel, 7843 BTU's worth of energy, has been injected into the carburetor along with 5.3 fluid ounces of methanol/water anti-detonate injection fluid.
In that one second, the hard-running Merlin has turned the propeller through 25 complete revolutions, with each of the blade tips having arced through a distance of 884 feet at a rotational velocity of 0.8 Mach. Fifteen fluid ounces of spray bar water has been atomized and spread across the face of the radiator to accelerate the transfer of waste heat from the cooling system to the atmosphere.
In that one second, the aircraft itself has traveled 704 feet, close to 1/8 mile, or roughly 1.5% of a single lap. Over 1.65 million foot-pounds of work have been done, the equivalent of lifting a station wagon to the top of the Statue of Liberty. The pilot's heart has taken 1.5 beats, pumping 5.4 fluid ounces of blood through his body at a peak pressure of 4.7 inches of mercury over ambient pressure.
Our pilot happened to inspire during our measured second, inhaling approximately 30 cubic inches (0.5 liter) of oxygen from the on-board system, and 2.4 million, yes million, new red blood cells have been formed in the pilot's bone marrow. In just one second, an amazing sequence of events have taken place beneath those polished cowlings and visored helmets. It's the world's fastest motor sport. Don't blink!
Now, I wonder if anyone has done this for a NASCAR vehicle?????
Old 02-11-2006 | 10:47 PM
My Feedback: (9)
Default RE: Interesting stats
Absolutely COOL rendering of th reqality of racing!!! Thanks ever so much!
Walt
Old 02-12-2006 | 02:36 PM
ORIGINAL: John ChristensenNow, I wonder if anyone has done this for a NASCAR vehicle?????
It's been done for top fuel dragsters.
I found the summation of that treatise interesting . . .
If you were tooling along at 200 MPH in your truly wild Corvette, and crossed the start line at the same time the top fueler started it's run, >the dragster would beat you to the finish line<.
Old 02-12-2006 | 07:00 PM
feep's Avatar
Very interesting. It shows the passion Tom has for the sport. On a less serious note I wonder how many of those seconds went by as he was calculating all of it for us
