 paint matching >
paint matching
paint matching
Old 08-30-2006 | 06:49 PM
Default paint matching
Does anyone know the best spray paint to match Solartex Dark Blue? Thanks.
Old 08-30-2006 | 09:21 PM
Campy's Avatar
Default RE: paint matching
Your best bet is to take some of the cloth to a paint shop and have them mix a quart of latex to match it. You will get an EXACT match. For the Solartex I suggest a flat or satin paint.
Unless you are running a gasser, you will need to clear coat the paint.
Old 08-30-2006 | 10:11 PM
Thank You, Do you know of a paint that would match that comes in a spray can? If I'm painting a cowl on a fabric airplane would it be best to paint the cowl flat like the Solartex or glossy?
Old 08-31-2006 | 12:59 PM
Campy's Avatar
I don't know of a matching paint in a spray can, however SOME auto paint places can make up a spray can for a minimal extra charge. If you use an automotive paint, the acrylics are USUALLY fuel resistant/proof.
As for the gloss, I would suggest a satin since that will be closest to the gloss on the Solartex.
Another option would be to use flat and then clear coat it with a satin waterbase polyurethane. I know MinWax has the waterbase "Polycrylic" in a spray can (Blue Label) in varyious degress of gloss rangine from flat to hi gloss
Old 08-31-2006 | 06:03 PM
Thank You.
Old 08-31-2006 | 08:59 PM
BTW, where would one get the minwax polycrylic?
Old 09-01-2006 | 10:35 AM
Most good hard ware stores will carry Minwax products. So does Home Depot and Lowes.
