Scale pinking tape
My Feedback: (25)
I need 1\9 scale pinking tape. Does anyone know how to make it? It seems as though everything available is too big. The tape should be around 3\16ths of an inch or so wide(no bigger then 1\4").
Mustang51
Mustang51
Someone once mentioned using that cloth medical tape you can get at the pharmacy it has scale pinks and is cloth so would work good. I was thinking of using that on me hurricane but dont know how i would be able to use it on my leading edges. also how it would hold up to a coat of poly U
Joe
Joe
My Feedback: (25)
Mustang51
Mustang51
I am looking for pinking tape, or a means to make pinking tape that would be 3\16ths", no bigger then 1\4".
Medical tape, along with Hairdressers tape is 1\2" wide, or larger, with pinks that are much too big for 1\9th scale application.
-Mustang51
To make pinks that small I have used the serrated cutter off a box of saran wrap, aluminum foil or wax paper. Glue the metal cutting edge to a stick of spruce to insure it's stiff. Using tracing paper (or tissue, or heavier paper) hold down the serrated edge on the paper the width you want and pull off the remainder, leaving a strip. Dope on and that should look about right.
Mustang51
You also might look around the hardware store at the hack saw and other saw blades. Some of those Sandik saws have 300 teeth per inch and are very sharp. You could use your covering material with a sharp blade like that.
Use the same method that Rsabast mentioned about stiffening the blade and holding the blade down on the table and pulling up on the material.
Have you thought about rib stitching?
E-mail me for some info on it.
[email protected]
ZZ
[email protected]
ZZ
CA
Womens hair tape [avail @ beauty supply stores]. It is 1/2 wide with a tacky backing. layout on a flat surface,cut it in half using a straight edge and overlap one to the other. [bingo! 1/4" wide] As you seal it with a good sandable primer the material can be lightly sanded. works for me. Mel.
