 Really Cool Scale Stuff! >
Old 02-05-2007 | 01:02 PM
rwright142's Avatar
Default Really Cool Scale Stuff!
I searched and found references to some of the products from Oregon Scale Aviation (OSA), but they are old posts so I wanted to update everyone. I was sent their information from Earl Aune, but has anyone else seen their products? There are incredible! I have no affiliation with them, honest, but wanted to share this with anyone wanting to have their planes look and act more like the full scale ones. OSA contact info at the bottom of this post. I bought their WingMan and it is great!
Products they offer:
o MicroGear Ultra
o Channel-3
o WingMan
o ThermaCowl
Descriptions:
MicroGear Ultra Features
o P51 and Corsair Style Landing Gear Control
o Air or mechanical retracts
o Air or mechanical doors
o Transmitter adjustable door servo travel
o Fully adjustable speeds and delays
o Recoverable Fail Safe for emergency landings
o Selectable locked or staggered mechanical main gears
__________________________________________________ ________
Channel-3
Let’s say you want your plane’s canopy to open when your in a landing configuration (gear and flaps down). This can be accomplished by connecting your radio receiver landing gear and flap channels to the controller inputs CH1 and CH2 respectively, and your sliding canopy servo to the controller output (CH1 or CH2 for servo reverse). Channel-3 will automatically open the cockpit canopy when your planes landing gear and flaps are lowered. The flap down position where the canopy opens is adjustable. The programmed dip-switch position enable set points are 20%, 50%, and 80%. Other exciting uses of Channel-3 are left to your imagination.
WingMan
WingMan was designed to enable the scale aviation enthusiast to control the folding or sweeping of wings in a scale-like manner. Additionally, it independently controls a latching servo that insures a positive lock of the wings, while requiring only a single channel of the transmitter. Many safety features have been incorporated in Wingman, in order to avoid inadvertent wing fold sequencing during flight. First, wing folding will only be initiated after an arming sequence of the transmitter switch.
Features
* Four selectable wing sweep or fold speeds
* Fast Down mode to simulate faster lowering than raising speed
* Servo travel adjust from transmitter (fold servo only)
* Servo reversing for both latch and fold servos
* Continuous control even with loss of transmitter signal
* Sequences uninterrupted by noisy or missing transmitter signal
* Digital noise filtering to prevent spurious sequencing
* Fail safe return to previous position if switched during fold sequence
* High quality multi-layer circuit board technology
ThermaCowl
ThermaCowl was designed to enable the scale aviation enthusiast to automatically control the opening and closing of cowl or cooling flaps in a scale-like manner. As the engine compartment temperature increases, the flaps open wider to allow further cooling. Because the flap position is controlled by temperature, ThermaCowl attempts to maintain a constant engine compartment temperature. This greatly aids in quicker warm-ups, and fewer lean run flame-outs. This control feature was found on many of the WWII era aircraft, and you will find ThermaCowl an excellent addition to your scale project to add that final touch of realism.
Features
o Proportional scale control of cowl or cooling flap position
o Requires only Power and Ground from receiver, does not load servo output
o Fully microprocessor controlled
o Adjustable start opening temperature
o Adjustable full open temperature
o No switches to configure, only 2 simple adjustments
o High quality multi-layer circuit board technology
o Designed and manufactured in the U.S.A.
Contact info:
Website: http://home.comcast.net/~rich2001/osa/
P.O.Box 1514
Beaverton, Oregon 97005-1514
Buz Hampton: [email protected]
Old 02-05-2007 | 06:06 PM
smcouch77's Avatar
Default RE: Really Cool Scale Stuff!
Thanks for the info. It does sound like some Cool Stuff.
Steve
Old 02-06-2007 | 10:52 AM
Buzz came to one of our club meetings a while back and showed off this cool stuff in his Corsair. It is truly very very cool. Watching the wing sweep down in scale fashion is just awesome. He just kind of simulated the cowl flaps for us but they are driven by engine temp. Just amazingly cool stuff.
Hmm, lets see how many times I can use cool in a post
Kent
Old 02-07-2007 | 08:26 AM
rwright142's Avatar
I am going to incorporate some of their products, like the WingMan which takes 1 channel to lock/unlock and raise/lower the wings. Here is a video that shows it:
http://www.youtube.com/watch?v=rBI1oA1Gjfc
Old 02-07-2007 | 10:21 PM
tailskid's Avatar
My Feedback: (34)
Now that's COOL!!!!
