 Position- and anticollision lights distribution patterns >
Old 03-06-2007 | 11:20 AM
Default Position- and anticollision lights distribution patterns
Hi all,
I've googled the web several times now in search of a site where they reveal the different light patterns in use on different aircraft. Till now I've been unable to succeed.
I'm aware of the [link=http://www.whelen.com/aviation/catalog/Anit-Collision%20Systems.pdf]FAA Position Light And Anti-Collision Light Distribution Patterns Requirements PDF[/link], but no (flash) patterns are mentioned in there.
The detail I'm looking for would describe how often which strobe/light flashes including intervalpatterns in ms (milliseconds).
[link=http://www.mes-avions-rc.net/PagesGB/PagesGBAirbus/GBairbusfeux.htm]Here's[/link] an example for an Airbus. I expect the builder uses the original lightpatterns.
All help is appriciated.
Old 03-06-2007 | 11:55 AM
Default RE: Position- and anticollision lights distribution patterns
There doesn't appear to be a specification regarding the interval of the strobe. The specification provides only that it is visible which determins its mounting and number on the air craft.
Old 03-06-2007 | 03:51 PM
BarracudaHockey's Avatar
It varies by manufacturer, you need to find out for the specific model you are working on.
Old 03-06-2007 | 06:38 PM
My Feedback: (16)
On US civil aircraft the position lights do not flash. On military aircraft they do and it is used for signalling between aircraft in flight. Also we used them to signal on the carrier when we were ready to unfold the wings, or start engines.
Hope that helped.
Dave
Old 03-07-2007 | 10:36 AM
BobH - That's what I was saying
BarracudaHockey - That's what I was thinking. But nevertheless still hoping there would excist a source in which a large group of aircraft types or manufactures would be mentioned with matching data on this issue.
c550 - regarding civil aviation: position lights never blink that's true, but anti-collision strobes do! And the latter is just the one i'm interested in regarding the blinking pattern.
Old 03-07-2007 | 10:46 AM
I suggest you email a few manufacturers of air craft strobes and ask them for their specifics. Thats the only way you are going to know.. And if you create your own strobe and have it flash.. who's going to know if you are 1 or 2 ms off?
Old 03-07-2007 | 11:28 AM
Nobody, but that's why we build scale. To perfect!!
But serious. It's not that one ms, but there are complete different patterns in use. That's worth searching for.
Old 03-07-2007 | 07:06 PM
aghost's Avatar
My Feedback: (13)
Once you know the strobe rate on a full scale aircraft, what would you like the strobe rate to be on the scale plane? Same rate or a slower scaled rate?
Brian
Old 03-07-2007 | 11:15 PM
fliir's Avatar
Wouldn't that be a FASTER scaled rate?
Old 03-08-2007 | 07:25 AM
You can't scale time.. So the rate should be the same.
Old 03-08-2007 | 10:09 AM
saramos's Avatar
I recently came across a mention of 85 strobes per second as being an FAA standard. This was in an article about making a flashing circuit using a microcontroller for a model nav light setup.
Scott
Old 03-08-2007 | 11:16 AM
Hmm that's pretty fast.. thats 85 hz, faster than the eye can discern as separate visual images I would think.
