HS-475HB for TF P47
HS-475HB for TF P47
Hey,
I have read forums on rcscalebuilder stating that HS-475HB servos have karbonite gears (which i already knew), but that they are sensitive to shock loads (which i didnt know[]). I have purchased 6 HS-475HB for my TF P47 .60 kit. I am going to have all of the options - retracts including tailwheel, struts, 4" robart wheels, flaps - so its going to be close to 12lbs. I also am going to have an OS 91FX in the front.
Do you think it would be ok to use these servos??? The last thing i want to do is lose a plane im have spend hours to build.
Cheers
Cheers
