Siemens Schuckert D.III 1/6th scale
One thing I have learned however (from painful experience) is never never fly if there's even the tiniest doubt about how the engine is running.
Hi Alan,first off congratulations on a superb model of a little known subject,second,thank heavens for soft ground and tall weeds ! I think we have all been there at some time or other, that l-o- n- g walk to the point of impact with a heavy hart to pick up the bits, and then to find it almost in one piece,now thats [/b]a good feeling !!
Now as far as the engine is concerned, I think the damage was done before it hit the ground. The R.C.V is a solid lump and it would take a big[/b] hit to damage the internals, so the fact that the propeller is unbroken and the forward part of the fuselage appears to be intact suggests that a part-seizure my have occurred. These engines run on a thermal knife edge and are prone to bearing faliers; I’ve had two go on my 60 S.P. I also have a 90 S.P. a c.d58 and cd 130 one thing they all have in common is a need for a lot of running in,and I mean a LOT ! the s.p. in particular .
Allthough you have taken much care with the cooling (love that ducted spinner ! ) the fact you had trouble finding the top end setting would indicate an over-heating problem.Buy a sato 110 and use the rcv for something else ( boat anchor ?!)
No matter what happened, crash or seizure, the engine seems to be shot. Once I pull things apart I will know more.
In any case, I have decided to drop the RCV idea. It originally made such good sense - the torque made possible a near scale sized four blade prop, the side starting worked well with the D.III spinner design which makes normal starting difficult, the exhaust worked out beautifully and the dummy engine workout is ideal. I even liked the "geared" aspect which is like the Siemens Halsey in the real plane.
My Saitos (in four other planes including a Camel and a Pup) have NEVER let me down like this. A friend, who won Scale Masters a year back in Team Scale, also has had problems with an RCV - and I understand he abandoned it too.
I have spent the last two days on the internet checking sizes and prices - and on my CAD system looking at the installation options... I looked at OS but the Saito 72 looks good in this cowl and can hang to the side, slightly down in a place where it will get some airflow. The exhaust workout is still a question but I have some ideas. Same with the throttle servo and linkage. I will have to rework the dummy rotary engine and install a new engine mount (no fun at this stage) but it looks like the way to go. Carb height relative to the tank is not ideal but I may consider an IronBay fuel regulator to resolve that issue. The OS-FS-70-Ultimate-P(pump) has space problems because the fuel lines go staight back and there isn't room for them.
Abu, I was thinking of writing you to suggest you consider alternates for your CI but you also are way ahead of me.
On a more positive note, I flew in the One Eighth Airforce meet last weekend in Mesa AZ with my VK Camel (wanted to take the D.III but....) and won the Commander's Award. It is really cool, a big wood plaque with three airforce "wings", a nice embroidered patch AND TWO 50 Cal. SHELLS! I can just hear Tim the-tool-man Taylor making a grunting noise.
In rechecking the Saitos, it looks like the new 82 uses the same case as the 72 and would also fit in my cowl. It has 1.5hp compared to 1.2 and should be able to swing a four blade 14x4 Zinger.
That would be great.
I will be giving this some thought. The more powerful engine might also run cooler.
You're probably right about the CD's although I wonder how it will compare with a Saito or OS. By the way, I had at about 2-1/2 hours on my RCV60SP before it actually flew, so it was fully broke in.
Abu,flying the 91 cd in a 'hack' model is a sound idea,back in the day did the same thing with new radio gear 'just in case' ! glad them days are gone, and you are almost right about the s.p. not so much a crap- shoot,just crap.Still, if I can sort out a water coolingset-up may use it in my C.1 yet !
They would still drain my 8.5oz tank too fast and I don't know for sure if they would really swing a four blade prop, which is the whole reason to go up to this size in the first place.
The OS engines in the 70 range, including their new 81 (obviously a response to the Saito), are too long and too tall to fit.
It looks like the Saito 72 is what I want. It still doesn't fit without some carving away, which I am not afraid off. I need to look at the California Dawn Patrol schedule and decide whether to order a new one or pull the one out of my Camel, at least for fitting purposes. Either way, there is no feasible way to make the Hemet Scale Masters Qualifier in early April. Plus, the tax man comith soon and my AZ house also needs some roof work...
Well it's time for me to go to Japan.
At long last Sunday i fly out of LAX. at 11:00 A.M. and should be in Japan 4:30 P.M. Monday night.[X(]
I would like to take this time to thank you for your help on my Cyclone 30 drawings and i would hope one day i'll run across another kit of the Cyclone 30.
I would love to pick up another kit SO IF ANYONE HAS ONE PLEASE LET ME KNOW.
I'll keep up with your work and might put in a line now and then.
See you on the web.
Charles E. Bates
Just some thoughts...
Charles, I used to spend some time in Atsugi (Nissan Tech Center is there) and always enjoyed a place called MacArthurs Garage, a cool bar near downtown. http://www.macarthurgarage.com/
I don't know how it is these days since I haven't been there in over ten years. Have a great time. Japan is fantastic.
I think it was a miracle that the plane was not totally destroyed.
I am still looking at engines to replace the RCV60SP... Do you blame me for wanting a different option??
Here is a shot taken by Del Perena and shown in our club newsletter. It was taken right after I rescued my D.III from the weeds and mud. Believe it or not, a lot of weeds had already fallen off before this shot was taken. It had been worse.
NO we do not blame you for wanting on a different option, i would also.
Thanks fot the tip about the bar, i'll check it out and let you know if it still open.[:-]
Live from Japan.[8D]
Charles E Bates
It was mounted to my break-in set up and started right up. After about 40 minutes, I am getting close to the final settings. The rpm range at this point is 1800 to about 6000, which I think is good enough to mount into the plane now. It runs very well, like every Saito I have had. My break in setup keeps coming loose as the c-clamps are not reliable. I can do the final adjustments in the plane.
The good news is that, if properly primed, it will start right up with a chicken stick – important because of the D.III’s fiberglass spinner complicates using a conventional starter.
The rpm range at this point is 1800 to about 6000...
Once it is mounted safely, I can make my final needle valve adjustments and get it to 9500 or so. I am using a 14-6 Master Airscrew for break in but will then probably go to an APC 15-4, like on my Camel. I wish I could drive a big four blade prop, like the one I had on the RCV but that is not going to happen.
EDIT!!!
I just realized I had my tach set for a THREE BLADE PROP.
So.... it is not 1800 (that would be amazing) and 6000 but rather 2700-9000 at this point... and still running quite rich.
Fitting the Saito 72 required a bit of grinding on the fuselage side. Next I must accurately center the mount on the firewall so I can drill for the new t-nuts. The tank will have to be pulled at that time.
Next, after relieving the fuselage a little more for better airflow around the cylinder, I worked on the exhaust system. The pipe has a couple of bends and needed trimmed by about two inches. It will look pretty good with only a small bit showing underneath.
