Help with JR X9303
I just received my new X9303 and frankly I'm slightly disappointed. I think a lighted display would have been nice and my neck strap holds the radio un level. I can deal without the light but I need the radio level. I see there are neck strap adaptors.
http://www.petenplanes.com.au/jr-spektrum-hitec-radio-control-equipment/jr-dsm-neck-strap-adaptor-silver-genuine-jr/prod_547.html
Will this work or are there any other suggestions.
I suppose it's possible to use the two (or three) finger technique with the radio suspended from a simple neck strap but it doesn't sound like the easiest thing to do.
BTW, when you buy into any expensive "system" (whether camera, stereo, or whatever) you are also always buying into an expensive set of accessories. Personally, I find $26 for a lump of metal a little outrageous. But then I can't really talk...as the owner of a Leica M6TTL.
I like a neck strap but not the tray idea. I guess my main concern is the neck strap adaptor breaking the transmitter case.
Maybe I could get use to a tray
Walt
Those offset TX neck strap adapters work quite well, my flying partner has one on his DX7. The only downside I ever read about them is that the bolts come undone if not locktited securely. I have no need for one as I am a "dumb thumber" and even on the sim cannot get comfy using the "pinch" method.
__________________________________________________ ___________________________________
Of all the things I ever lost....................................... I miss my mind the most!
Yes I saw this site and have thought about trying this myself. Didn’t know he was selling kits. I re-looked at the site but cant find where to get the info on the mod. Can you give me a hint as to which page or a link thanks.
<o></o>
I decided early on that I wouldN'T repeat this with RC equipment. I've got a great $200 radio. With my simple WWI models that's all the radio I'll ever need. And that's already a heck of a lot more sophistication than WWI pilots had to work with.
Yes butthe COOL factor??
Heck you might stink as a photographer, but you'll look good out there taking pictures. I might not be able to keep a plane in the air, but boy I sure look like I know what I'm doing, when I get to the field and pull out my JR 12X or 14 channel Futaba.
All kidding aside, for meI wanted a radio that felt good in my hands and that I trusted. I also only wanted 1 radio that I can use to fly everything I have or am thinking of getting (planes and helis). This for me was the JR line of radios. If I only needed to worry about 4 channels then sure I would have a less expensive radio but that's not the case for me so I went middle of the pack with the 9303.I have solved the balance problem with the adaptor and the lighted display will just have to be unlit for now. Other then those two issues I had I do really like this transmitter after messing with it for a while.
The only difference between Men and Boys is the price of their toys. So........... off to the accessory store I go
That’s true to a point; however features on the more expensive models in anything make the job at hand easier. That’s not saying I can’t dig a ditch with a shovel but a backhoe sure would be nice to have. I don’t need the best of the best but I do want quality and performance in what I buy. Unfortunately this comes at a $$cost $$ and sometimes that hurts.
Not trying to be argumentative on this.........just wanted to let you kow my reasoning behind my decision. But I will be honest also......... a lil bling bling on the RC toys does bring ooooohhhs and aaaaahs from the flying field buddys. Ok, so I am caught! Now turn on that backlight so I can comb my hair in rear view mirrow on the way home from the flying field!
