Changing an airfoil profile
RE: Changing an airfoil profile
I don't know how accurate it is, but Wylam's drawings of the S.XIII are also in the MAN Scale Aircraft Drawings (Vol.I) book. Razor thin with a razor thin LE would be the only possible description! [:'(] It's amazing that they bothered to put lightening holes in it at all! But then, with close to 100 ribs on the two wings, I guess each one didn't need to be that strong.
NJ
Hmmm. 'bout time some RCU'er built a working wind tunnel - WWI vintage design, 1/4 scale, of course. My third grader has a science fair coming up this Spring. Gives me an idea....
ORIGINAL: Mode One
Does the SPAD have lightening holes? SPAD used a pile of ribs in their wings! My guess is Balsa USA may have cut down on the amount of ribs used in the wing, also.
The BUSA kit has a correct rib count. That's one of their advertising statements. I also believe that cap strips are not used.
Shoot, I'm just going to have to drag the dang thing out and look at it.
#31
NJ
Interesting - of course it's easier/cheaper to test wing sections rather than a full airframe and requires a much smaller tunnel - like the Wrights used. Here a couple "educational" windtunnels from NASA.
http://www.fi.edu/flights/first/makebigger/index.html
http://sln.fi.edu/flights/first/makesimple/index.html
#32
ORIGINAL: khodges
The fullscale wing has a top edge ''bow'' and a bottom edge ''bow'' with connections between them (not a trusswork). The wing has little cantilevered strength. With all the wires in place and properly tuned, each wing depended on the other for rigidity.
ORIGINAL: Mode One
I'm not following what you mean by: The fullscale wing has a top edge ''bow'' and a bottom edge ''bow'' with connections between them (not a trusswork). However, I certainly agree with: "The wing has little cantilevered strength. With all the wires in place and properly tuned, each wing depended on the other for rigidity".
I've only seen a covered example of the BUSA SPAD, so cap strips may not be used.
Good luck with your endeavor and above all have fun!
#33
NJ
I've attached some pdf's I sent Ken - one shows the Gott. 303, which I used for the tip section of my Pfalz DXV and the 303 fattened to 15% for the root section. 2nd and 3rd pdf's are the front/back 303 scaled to 14" and 15" chord for Ken's airplane (I figured it's eaier to print two 8x11.5 and tape them together). Rummaging around, I also found the Gott. 381, which is a tad thinner and would be another option.
