Seidel 7-70 radial: Help me decide!
#302
My Feedback: (324)
MO
RE: Seidel 7-70 radial: Help me decide!
Ok,but alot of us have New engines and a engines life should Start with the best to keep it going for a long time,,,in auto racing they use a "Break in oil " at first,I realise that is a different application than our models , but I would think First start up is the most critical ,so I guess what I am asking is what to start out with and should we stick to that exclusivly? or change to something else for some reason.
I ask because I have Amsoil "Interceptor Synthetic 2-cycle oil" which is "Supposed "to be very good
Gee I wish Seidel made fuel!
#309
If they recommend Synth then it must be ok, I have never heard of Glissol but it must be oil, probably from Germany thats where the engines were designed and developed. Aks Abu to ck with his German friend. Unless you want to obsess over mixing fuel you need to come up with a good break in fuel anf then a nornal run fuel.
#311
ORIGINAL: GeeBee-RCU
That is 6 different fuels!!??
But the ONLY question for me is where to buy methanol.
#314
If only small quantities of methanol can be had commercially, buy synthetic FAI fuel, which is not technically FAI fuel but is available, and dilute it with the methanol. If FAI is impossible get some 5% and do the same. You might be able to find methanol at a high end furniture/ woodworking store, which is used in shellac; most shy away now because of health but there is always purists out there. If someone is making bio-diesel in the area, methanol is a major part of the process; they had to get it from somewhere.
#315
ID
Morgan Fuels maybe? Cool Power Omega is 0% nitro but it's 17% oil. Synthetic and "''de-gummed" castor....they have a Super-tiger fuel that is 12% oil, but it's got nitro...crazy....
Edit: I found this on Tower's web site, regarding the OS FR7-420 Sirius radial....
REQUIRES: Fuel: Aircraft blend 5-10% nitro content with 8-10% lubricant
content (it is suggested to dilute commercially available 15%
nitromethane and 18% lubricant fuel with methanol half and half to
make a 7.5% nitro and 9% lubricant fuel)
So I suppose you could dilute FAI 0% nitro 17% oil fuel half and half with methanol.....
#316
ORIGINAL: V2PLUS10
(it is suggested to dilute commercially available 15% nitromethane and 18% lubricant fuel with methanol half and half to make a 7.5% nitro and 9% lubricant fuel)
TFF, I did find a news item about Japan looking to develop overseas partnerships for methanol production (for bio-fuels), for example, the article mentioned a project in Ghana. So SOMEBODY in Japan is using methanol! But at this point, it's sort of like me contacting Dupont and asking them to sell me a quart of chemicals. I'm sure I'll find a source.
#317
ID
I've read in a couple of places now that you can buy 100% methyl alcohol by the quart at Home Depot. I'll have to give it a try.... google advises that methyl alcohol and methanol are the same...
Other recommendations are go-cart racing tracks, and other racing suppliers. Easy to say, tough to find....
#318
ORIGINAL: V2PLUS10
...google advises that methyl alcohol and methanol are the same...
#319
Well, I found my source, through a friend of a friend who has a friend who runs an animal hospital and has 99% methanol and who is willing to sell me a few liters. That's a start!
#320
Good morning Don,
shouldn't it be possible to import a small quantity of oil to Japan?
In that case, contact my supplier. He'll deliver Aerosynth 3 to you - the best synthetic oil there is on the market! And mind you: for 1 liter of Oil you can use 19 liters of Methanol!.
His Name is Jörg Küppers:
[link=http://www.spritonline.de/product_info.php?info=p11_aerosynth-3-oel-pro-liter.html]Sprit Online[/link]
Cheers, Martin
Cheers, Martin
#321
Martin, thanks for the link. I think I'll first try to find a local source. I'm curious though why methanol is so easily available in Germany (at least on that website) white it seems to be some kind of State Secret here in Japan.
http://www.spritonline.de/index.php?...0dcca19c5b9415
As far as importing oil, I would imagine that technically it's going to be on those "no air shipping" lists. [:@]
#322
yes, you might be right with that. However I thought this is probably mostly true for Methanol - very flameable substance. Oil on the other hand? Can't I bring baby oil in my suitcase? Olive oil from Greece as a gift? That's why I thought it is worth a try...
Cheers, Martin
PS: All that fuel and oil talk makes me realize that I haven't burned any lately. But what with fall having set in here in Germany - rain, cold, windy - I'll have to get used to the "turkey" until spring, I guess. Same procedure as every year...
Cheers, Martin
#323
I see that in their check-out procedure there's no way of entering a non-European address (actually only about 8 countries are shown), so I assume that means they don't ship overseas.
