exponential
Depends on your transmitter on how to apply it and personal taste on how much.
I'd start with 20 percent and adjust from there, it may need more or it may not need any at all depending on you and the plane.
Do you feel the elevator is too sensitive?
What radio are you using?
Please take note that Futaba radios have a NEGATIVE value of exponential to soften around neutral while JR and Spektrum radios have a POSITIVE value of exponential to soften around neutral.
I don't know about any other systems, but it's right there in your manual.
You do read the manual, don't you?
NC
Another option also...use your dual rates so you can have no expo for cruising and then turn on the expo for landing. Best of both worlds? I agree with everyone else about starting at about 20-30%max.
Cheers,
James
Cheers,
James
ORIGINAL: Ed
Yes Mr. Pettit, I did read the manual .
Ed
Ed
This seems like a pretty harsh response to someone that is only trying to offer helpful advice.[&:] [X(]
