Tips
How could you produce a aluminium finish on your scale project? How would you add rivets?
When adding rivets does it take a lot of time to do? Please help thanks Tails |
RE: Tips
Tails,
Try this link. This is what most guys use for metal finishes. http://www.scaleaero.com/flitemetal.htm They have a rivet tool too, but the web page is all screwed up. Most metal finishes have flush (not raised/domed) rivets. In these cases most guys will burn the rivets into the finish with a heated brass tube, mounted to a soldering iron. Don't know what the availability of this product is... they list a lot of stuff on the ScaleAero web site that they don't have in stock. Tom |
RE: Tips
Also, BVM sells a product called Metal Kote. It is somewhat expensive but gives superior results. Just check out some of the F-100s on their web page. I am going to use it on an F-86 that is the first project for this building season.
| All times are GMT -8. The time now is 07:46 AM. |
