RCU Forums
-   RC Scale Aircraft (https://www.rcuniverse.com/forum/rc-scale-aircraft-169/)
-   -   TF cessna 182 prop? (https://www.rcuniverse.com/forum/rc-scale-aircraft-169/464024-tf-cessna-182-prop.html)
dany_maia 01-06-2003 11:21 AM
TF cessna 182 prop?
Hi.
I have a TF cessna 182 in construction and a OS 120 Surpass III w/pump. What would be a good prop and scale prop for this combo? I do not have enough ground clearance for a 16 diameter prop and want this plane to fly scale, not to speed. I imagine that this engine is only needed at fuull power for takeoffs, isnīt it?
What idle and top rpms will the engine run with the prop you say?
Thanks.
iFLYrc_Vic 01-06-2003 02:16 PM
TF cessna 182 prop?
I have an OS 1.20 four stroke on my TF Cessna. You are correct that full power is only needed on take off - then back to maybe 1/3 rd. I use a 3-blade Master Airscrew 14 x 8 and get about 10,000 rpm at full throttle. I also have a Gropner 14 x 8 but it does not fit in the spinner.
