RCU Forums
-   RC Scale Aircraft (https://www.rcuniverse.com/forum/rc-scale-aircraft-169/)
-   -   Looking for Chart Tape (https://www.rcuniverse.com/forum/rc-scale-aircraft-169/5322467-looking-chart-tape.html)
Low Show 01-25-2007 05:42 PM
Is there a national commercial resource for 1/32, 1/16 Chart tape, I'm trying to finish up my glassed KMP OV-10 and am running low, the last place that I picked it up at no longer offers it. Thanks...Don
TLH101 01-25-2007 06:04 PM
RE: Looking for Chart Tape
http://www.suppliesnet.com/index.asp...S&Category=288
grbaker 01-25-2007 06:06 PM
Look here:
http://www.suppliesnet.com/index.asp...S&Category=290
Looks like Terry beat me by a couple of minutes.
Low Show 01-25-2007 08:00 PM
Thanks Guys...Don
blw 01-25-2007 08:36 PM
Low Show,
What are you using it for? I use ScotchCal for going around canopies on planes with glow engines. I get it at the auto parts store. For non-glow use I have a lot that I've saved for some 20 years. Chartpak stuff.
uscra112 01-25-2007 10:05 PM
Another source - Charrette.com
http://www.charrette.com/store/catal...tape&x=20&y=12
caster2 01-25-2007 11:04 PM
Pearl Paint in NY
cmoore806 01-28-2007 08:20 PM
Could someone help me figure out which type of tape I would use for a 1/5 scale plane? I figure the crepe tape is good for curves, etc. and the gloss is what I would want so the primer wouldnt stick to it. But what width for a 1/5 Scale bird?
saramos 01-28-2007 10:15 PM
If it were me, I'd still stay with the 1/64th.
Scott
Low Show 01-31-2007 11:54 PM
It looks as if I'm going to have enough to finish the Bronco , again thanks for the sources for future projects.
Scott do you use 1/64 most of the time and on all Scales of Airframes?
blw 02-02-2007 09:43 PM
Does chart tape come up from glow fuel?
Low Show 02-02-2007 09:53 PM
I'm sure it will, I use it after glassing, fill, and primer then lay out your panal lines, put down the chart tape, then a couple coats of primer over the tape, then remove the tape and then shoot your final color coats. I hope this helps....Don
saramos 02-02-2007 11:03 PM
1 Attachment(s)
So far, I've only used it on 1/7 scale. However, the panel lines on full size planes are very small, and I would think the fine line that 1/64" tape makes should be sufficient for scales up to 1/5th or maybe even 1/4. One area of exception might be for simulating the joints of removable panels such as engine cowls. There you might want to use 1/32" just to make them more pronounced than the rest of the panel lines. Accenting panel lines when weathering is what will really make them pop.
Scott
