RCU Forums
-   RC Scale Aircraft (https://www.rcuniverse.com/forum/rc-scale-aircraft-169/)
-   -   P40 ready, comments? (https://www.rcuniverse.com/forum/rc-scale-aircraft-169/7106615-p40-ready-comments.html)
nilo 02-20-2008 10:45 AM
1 Attachment(s)
Just wanted to post some pics of the completed P40 I started in 2004.
Yes, after 4 years struggling with limited budget, is finally ready.
Comments will be appreciated as I have lots to learn. This is the first kit I built.
Kit: TopFlite P40 warhawk gold edition 64" wingspan
Engine: OS91 4 stroke
Retracts: Century jet P40 retract
Final weight: 11 lb 4oz
Prop: Master Airscrew 14x7 3-Blade
Finish: monokote
nilo 02-20-2008 10:47 AM
RE: P40 ready to fly, comments?
1 Attachment(s)
more pics.
Walt Thyng 02-20-2008 11:01 AM
RE: P40 ready, comments?
Nice job. First kit or first r/c airplane? In any case get someone else to maiden it for you. I can tell you have a lot invested financially and emotionally, both of which make for overly nervous first flights.
Walt
jmohn 02-20-2008 11:11 AM
Great job! It looks awsome. The weight seems high to me, but I fly them electric. My P40 was 8 lbs and fly very fast. It did not like to slow down much on landings or it would tip stall hard.
nilo 02-20-2008 11:31 AM
1 Attachment(s)
This P40 was my first kit.
Here are the other planes I fly.
Nilo
jmohn 02-20-2008 12:03 PM
1 Attachment(s)
I have a Tucano slightly larger than that one. All electric again and 10 lbs. Great plane!
nilo 02-20-2008 12:10 PM
My is about 65" wingspan, with a Saito100 on it.
Where you got your from?
Nilo
jmohn 02-20-2008 12:22 PM
Must be the same plane then, so is mine. Yours just looked smaller. I got mine from Nitromodels. It's very fast and jet-like. Turns a lot of heads at the field too.
faurrlemos 02-20-2008 07:31 PM
Nilo's tucano is from Juniaer, Brazil made with fiber glass it's more heavy than your
jmohn 02-20-2008 07:50 PM
Mine is fiberglass fuze and fully sheeted wings and weighs 10 lbs.
Jeff
US185Damiani 02-21-2008 07:31 AM
Nilo,
with the .91 you'll find it a bit marginal with the 14x7 3 blade.
You will want to go to a 14x6 or 14x7 2 blade.
I have the same airplane with the same engine in the same weight range.
Make sure you fly it on the wing, long take off roll and shallow climb out, let it build up speed. The P-40 will tend to be snappy at slow speeds.
Good luck with it!
jeffk464 02-21-2008 10:11 AM
Yes, the os 91fs likes a 2 blade 14x6.
mike early 03-31-2009 09:34 PM
Whatever happened to this wonderful P-40?
frets24 06-01-2009 05:58 PM
I Know, right? You find an interesting thread and a nice build,it's ready to maiden, "I'm goin' this weekend", and then.............................................. ..............(sound of crickets chirping)
Like the national inquirer, I want to know: did it maiden OK? If not, I'd like closure. If so, I want to hear of, and vicariously experience, the joy of seeing one of your planes giving you the thrill of success. That's one of the reasons we are in this hobby and we go to the common field or to the club field to fly and don't just find some suitable place out in tne boonies to go fly. We want to share the joys and sympathize with the failures of our fellow hobbyists.
Don't leave us hangin', man!!
mike early 06-01-2009 07:58 PM
Thread starter's Last Login: 3/9/2009
He eventually might see my question eventually and tell us.
I imagine it is a sad ending...or he'd be happily telling us all about it the day after...
Let's hope not!
