RCU Forums
-   RC Scale Aircraft (https://www.rcuniverse.com/forum/rc-scale-aircraft-169/)
-   -   Help with B-52 (https://www.rcuniverse.com/forum/rc-scale-aircraft-169/7891362-help-b-52-a.html)
wartoy2020 08-27-2008 10:03 AM
Help with B-52
HEllo all,
I am wanting to build a B-52 with around a 6 foot wing span. Yes, I have read most of the threads around here of buids but they are a few years old. I would love to come across someone who would kit out a BUFF becuase I am not a good scratch builder. I have found plans but I don't know what "tiled" or "A4" plans means.
I saw a kit for a pusher prop but it is a little smaller than what I want. I don't mind a pusher prop, I just want as much size as I can get up to 6" WS. Electric pusher or EDF is fine. EDF would be cooler...
Anybody offering any help or advise?
Thanks folks in advance...
Gorden
Props4ever 08-27-2008 12:30 PM
RE: Help with B-52
Last i know CEADER HOBBIES were working on EDF version of B-52 arf model, at present i don't know the status of it. You may want to do a search on at this site to see the updates on it. Best of luck!.
omcusnr 08-27-2008 02:58 PM
RE: Help with B-52
Gordon,
Tiled and A-4 refer to printing the plans on smaller sheets of paper (the A4 Euro eq 8.5X11) and taping the "tiles" together for a larger plansheet. If you have access to an electronic plan, there is usually a Kinkos or engineering copier place nearby that could print the larger plansheet at its original size. You might want to get two sets done. One to build on, the other to cut up for parts.
I have no idea of who would kit a B-52.
Reid
Just thought - What format "plans are you talking? 3-views, construction drawings, vues with sections??? also, what program are the associated with? CAD or drawing software?
wartoy2020 08-27-2008 09:39 PM
RE: Help with B-52
1 Attachment(s)
HEre are the files I was referring to.
teebox11 08-28-2008 12:53 AM
RE: Help with B-52
I have some plans, complete, for a GIANT Buff. Now, what is giant? If I remember, about 120" or so. These are sheets, maybe 24-30"x8-10'. Could be, Laser Lizard has them in the computer. If not, they can cut a short/full kit for you from plans. If you like, e-mail me directly ([email protected]) and I'll go check the exact specs on the plans. I have been seriously thinking about that as my next project after my MIBO A-10, using all turbine.
Props4ever 08-28-2008 04:58 AM
RE: Help with B-52
You know what, now i remember i might have plans for slope sourer model of BUFF in my old HD!!, let me check and if i do i will post Jpg here of it.
Props4ever 08-29-2008 12:08 AM
RE: Help with B-52
Hi wartoy2020,
I have found Jpg.s of the B-52G plans that i mentioned to you in above post, now only if i can get them from CD to my HD and then post them here..that is set of wing and fuselage plans at 78" WS with dummy engine pods.
spad 09-01-2008 01:44 PM
RE: Help with B-52
Hi wartoy2020
Try this link:
https://shop.traplet.com/product.aspx?c=1020
it's for a set of plans for a very well known 60" 8 fan -G model designed by Chris Golds, one of the UK's most respected electric jet designers.
I know it's not 6' but it's a start.....;)
cheers
Rick
Props4ever 09-01-2008 04:29 PM
RE: Help with B-52
You can get B-52 plans form www.unclewillieplans.com also.
Direct link: http://www.myunclewillies.com/about4.html1.html
