RE: First build, third plane. Looking for recommendations (must be scale)
<p class="MsoNormal" style="margin: 0cm 0cm 0pt"><font size="3" face="Calibri">MD is right about the longevity of the pup,mine was twenty years old when I sold it on ,however, I did re-furbish it twice in that time ! But that’s the thing with ‘stick & rag ‘ planes, repair/rebuild is much easier<span style="mso-spacerun: yes"> </span><span style="mso-spacerun: yes"></span>(just remember to keep the plans ) I did and I miss not haveing a pup to the point that I may have to buildone from scratch ,ho-humhttp://www.rcuniverse.com/forum/js/f...n/rolleyes.gif</font></p><p class="MsoNormal" style="margin: 0cm 0cm 0pt"><font size="3" face="Calibri">I had the Mk 1 pup that was more straight forward to fit a 4-stroke to ( IMHO ) my one first had a ST G23/46 2s and then<span style="mso-spacerun: yes"> </span>a ASP 61 4S (same size as a 52 ) <span style="mso-spacerun: yes"></span>mounted upright with no problems , I also had the one servo for the ailerons ,but converted to the duel set-up’ much better !!</font></p>
Jeff - you make an excellent point. My primary purpose for building from a kit is so I can improve my practical skills. However a very close second is that I know that if I damage the plane I will be able to rebuild/fix it.
Cheers, Dub |
I had the puppeteer and its a beautiful kit but the problem that I encountered was measurements are not in inches and pounds etc.if that is an issue you might want to to take a crash course in metrics..I also built ansd still fly a dynaflighte SE5A.it is true funscale and you can spruce it up as much as you want.I take it to rhinebeck in the fall and it blends in with the big guns.
my preference these days would be a balsa usa kit .they are easy and straight foward the fokker D8 you mention is available and a wonder plane..comes in quarter scale and 1/3 ..its readily available and acess to parts and finishing options like guns etc are available here in the usa ..I built a balsa usa 1/4 cub love it.. |
opps sorry I see your in the UK where flair is readily attainable my apology.
ORIGINAL: cloudancer03 opps sorry I see your in the UK where flair is readily attainable my apology. |
you'll love the flair kit as well.if you want to lust over a kit gander a lookie at the "arizona "rc kit web site..they are museum quality with wall street prices..
ORIGINAL: cloudancer03 you'll love the flair kit as well.if you want to lust over a kit gander a lookie at the ''arizona ''rc kit web site..they are museum quality with wall street prices.. |
ORIGINAL: dubcat ORIGINAL: cloudancer03 you'll love the flair kit as well.if you want to lust over a kit gander a lookie at the ''arizona ''rc kit web site..they are museum quality with wall street prices.. |
Thats right, stay away from Arizona models, attractive as they look, or you will probably regret it to no end.....
BTW...don't you use metrics in England now?? |
ORIGINAL: Mein Duff Thats right, stay away from Arizona models, attractive as they look, or you will probably regret it to no end..... BTW...don't you use metrics in England now?? |
More importantly, what do you measure in on a small scale for models and around the house etc. ...not long distance driving miles
It varies to be honest. For modelling I do prefer metric but I don't know what people generally use. Balsa thickness still comes in imperial measurements though as far as i know.
ORIGINAL: dubcat It varies to be honest. For modelling I do prefer metric but I don't know what people generally use. Balsa thickness still comes in imperial measurements though as far as i know. |
When you add to that the fact that a gallon is a different size depending on if you are in the UK or the US ...
Well.. WE ARE DOOMED! :) |
ok you guys got me..I have learned to use a metric ruler since my experience with the flair kit..as for arizona I have heard thesame things but on paper the kits look awesome.personally I would build a balsa usa or zirloi kit.straight foward with conventional construction.
1 Attachment(s)
ORIGINAL: dubcat Thanks Mein - I was really hoping to have a fully enclosed engine to be honest. Can you post some pictures of your one please? Specifically the cowl and engine. Thanks, Dub To give you an idea of the deatiling you can add...some of it requires pre planning ..Scale functional / sprung landing gear ..Fake landing / flying wires from black elastic thread (local sewing shop) ..Spruce struts (instead of alu supplied) ..Tail rudder raised off fuse ..Functional sprung tail skid ..Cut out in top wing center section ..Alu panels on forward fuse....circular burnishing polishing |
ORIGINAL: Mein Duff ..Fake landing / flying wires from black elastic thread (local sewing shop) |
How would you attach the .08 wires quickly and still have them add strength?...
It takes me about 15 minutes to get flight ready even with my elastic wires. |
Mein - she is LOVELY! Really inspiring! I especially love the burnishing on the ali front! The engine is not protruding much at all - and the cut out is minimal i agree.
ORIGINAL: Mein Duff How would you attach the .08 wires quickly and still have them add strength?... It takes me about 15 minutes to get flight ready even with my elastic wires. On my Pup the rocker arm caps of my Saito 56 just barely made contact with the cowl so I ended up cutting out little slots in the cowl. But now that I think about it I could have just hammered in some little "blisters" and that would have solved the problem. The thing is though that the Puppeteer (like all the Flair and BUSA kits) are strictly semi-scale so there's no point in obsessing about something like a bit of engine protruding. There will plenty of other things on the model that are less scale than that. |
| All times are GMT -8. The time now is 08:09 AM. |
