Go Back  RCU Forums > RC Boats > RC Scale Boating
LT Army tug power train >
RC Scale Boating Enjoy rc scale boating? Talk about it here.
Old 02-23-2024 | 12:56 PM
Default LT Army tug power train
I’ve resurrected a project that was shelved decades ago. Planking is about 1/4 done. It’s being built as a 1/24th scale of WWII Army tug, LT5 (NY) or LT4 (CA) for example. It’s 56” long, 12 1/2” beam. Plans show a 4”, 4 blade prop. I have decided not to use a single direct drive brush motor so I can increase run time and make it more adjustable. I have a number of reduction drives and want to use a brushless motor and fully proportional esc. I could go anywhere from 1.5:1 to 4:1 reduction. Any suggestions as to what motor/esc combo might be appropriate? It doesn’t need the big power or tremendous rpm of direct drive speedboats. I think I’m targeting 2500 to 3000 shaft rpm. Anyone with experience please correct me if I’m wrong. Any help/input will be appreciated.
Old 02-27-2024 | 12:59 AM
I cannot guide you directly to a motor... What I CAN do is first of all point out that there are motors that are wound to spin 2500~3000 rpm and that would save you the hassle of a reduction drive, as well as the possible gear-noise. For 12V you would be looking for motors with a kV rating of about 250, give or take.
But if I may be so frank: 2500~3000 rpm on a 4"fourbladed prop, you're talking about very roughly 250~400 Watt (power calculations on ships propellers are notoriously tricky), and that is an awful lot of power, even for a 56" boat. You're easily going to pull a rowboat with two adults in it around with decent authority. 250 Watt with certainty is more than a single oarsman in a rowboat can sustain for reasonable duration, so your boat will win in a tug-of-war, that kind of authority... Careful estimation it's something like 10 or 15 lbs bollardpull, probably more,
Anyway, whichever motor you choose (high RPM with gearing or direct drive) you'regoing to take into account that for example on 12V it is going to draw at least 20 Amps, probably significantly more, for a geared drive you would be looking for about kV1000 and rated for miminmum 20 amp, for direct drive kV250 and 20 amps (I think the 20 Amps is the bare minimum you should look for).
Just for frame of reference: A Sullivan starter as used for glow engines (planes) is about kV250 but only rated for approx 10 Amp... So that is a fairly big motor you would be looking for.
I myself am currently working on a 44" boat with a 4" prop, and I am targetting 1500 RPM, which should be about 80~100 Watt, and theoretically result in at least 6 lbs bollardpull. In-water tests in the bathtub it was quite a handful to hold in place by hand...
