RC Scale Boating Enjoy rc scale boating? Talk about it here.
rudder
Old 01-25-2006 | 10:25 AM
Default rudder
Dose anyone know were to get a lobster boat style rudder one that connecto to a hadr point at both ends. Im putting it in a gas powerd 42" lobster boat hull
Old 01-25-2006 | 12:04 PM
Default RE: rudder
please help i cant find anywere
Old 01-25-2006 | 12:56 PM
Default RE: rudder
maineoscarfish,
To tell you the truth, I can't remember seeing one advertised. A single point type mounted rudder, yes, but not the other (and don't take that for more than it's worth). It would seem that for rudders of that type, the builder makes them. Shouldn't be all that difficult, but then I'm not doing it, huh?
- 'Doc
Old 01-25-2006 | 01:02 PM
Umi_Ryuzuki's Avatar
Default RE: rudder
It would be simple enough to build one.
Some people epoxy wood around a brass rod and sand it to shape.
Others have soldered a thin brass shape to the rod, then sandwitched it with wood.
I typically cut a rudder shape from 1/16th inch thick brass sheet then silver solder that to an
1/8"-5/32nd inch brass rod.[quote]It would be simple enough to build one.
It could be done something like how the prop guard is installed in the images below.
RGinCandada posted a way to remove the rudder post, if I find that, I will link it here.
Old 01-25-2006 | 02:49 PM
Default RE: rudder
Thanks guys i guess ill build my own
