Go Back  RCU Forums > RC Boats > RC Scale Boating
Reload this Page >
the unofficial home of the dumas dauntless
RC Scale Boating Enjoy rc scale boating? Talk about it here.
Old 07-04-2013, 09:46 PM
  #4651
dauntlessfan
dauntlessfan's Avatar
Default RE: the unofficial home of the dumas dauntless
Rthalls - I don't know of a Dauntless hardware kit that comes with 2" props, or any props actually. Which hardware kit are you considering?
Old 07-05-2013, 03:17 AM
  #4652
rthalls
My Feedback: (63)
http://web4.hobbylinc.com/gr/dum/dum2341.jpg this is the site
Old 07-05-2013, 06:20 AM
  #4653
Hydro Junkie
Hydro Junkie's Avatar
If that's the Dumas hardware kit, you may want to look at the MACK Products hardware kit for the Dauntless before you spend any cash. I'm not saying the Dumas stuff is bad, just pointing out that there are other options. Here's a link for their site:
http://www.mackproductsrc.com/power_packages.htm
Old 07-05-2013, 06:35 AM
  #4654
rthalls
My Feedback: (63)
thanks for the information , trying to get prices on everything [ sticker shock ] makes the boat kit cheap........new to boats been building airplanes for 35 years
Old 07-05-2013, 06:42 AM
  #4655
dauntlessfan
Okay now I see, thanks. When I built mine, I bought kit 2332 which doesn't include props. Also like Hydro said there are other options out there more well suited to stronger motors like the 700bb. I replaced my Dumas shaft struts with MACK brand and most builders here use the heavy duty couplers offered from harbor models.
Old 07-05-2013, 07:35 AM
  #4656
Hydro Junkie
DF, I'm not familiar with Harbor Models. Do you have a website for them?
Old 07-05-2013, 07:51 AM
  #4657
rblubaugh
Hydro,
Harbor Models, http://www.harbormodels.com/
Bob
Old 07-05-2013, 08:05 PM
  #4658
deep sky
i was just looking at that dumas hardware kit that is a old kit i had the same one i called dumas and they had me send the struts and props to them and they replaced the struts and upgraded to the new props for free.they told me the old struts were weak so now i have 1/3/4 new props and better struts.the new props dont use drive dogs
Old 07-06-2013, 05:20 AM
  #4659
rblubaugh
Deep,
Were they the ones you already had on the boat, the painted red struts? Was that their kit #2341 which comes with props or kit #2332?
Silly question. Must have been hardware kit #2341 because you said you got new props, duh.
Bob
Old 07-06-2013, 08:45 AM
  #4660
deep sky
i belive i did that to boulth boats when i got this set the bushings fell out so i called dumas agin and they sent new shafts and struts
Old 07-09-2013, 04:04 PM
  #4661
rthalls
My Feedback: (63)
enjoy reading these hints , I just started my build of the dauntless and getting some of the parts together . I have two 700 brushed motors and a 12v lead acid battery but don't understand all the different speed controls ? I know I need a brushed control at 30amps but where , the more I look the more confused Iam any help is appreciated............. thanks
Old 07-09-2013, 05:04 PM
  #4662
dauntlessfan
RT - for running two 700 motors you'll need equipment rated at more than 30 amps total continuous. I tried a single 30 amp speed control on two 700's and it only lasted a few short runs in the Dauntless before permanent failure.
The ideal setup would be two electronic speed controls (ESCs), one for each motor. Check out mTroniks marine ESCs. They're rated by continuous amps for output and voltage range for input. They're waterproof and come with a good warranty. And they're not too expensive.
If you go the dual ESC route, be sure to read up on how to wire it here in earlier posts to avoid damaging any components.
Old 07-09-2013, 05:23 PM
  #4663
rthalls
My Feedback: (63)
thanks again and after checking it I still have no idea what there numbers mean or what I need
Old 07-09-2013, 06:25 PM
  #4664
deep sky
hi df i think you should tell him what yours are as i think you went with the 40 amp vipers dident you
Old 07-09-2013, 08:21 PM
  #4665
dauntlessfan
My boat has a "Viper 40" on each 700-sized motor to control its speed.
The 40 amp continuous current limit means it's rated to handle 40 amps for long periods - so the motor it's controlling should draw less than 40 amps at full throttle under load (i.e. in the water pushing the boat). For this spec, a larger number means a more robust ESC and more powerful motor options.
It has 6-12 volts input voltage. That simply means the motor battery(ies) plugged into the ESC must stay within this range. For this spec, a wider voltage range gives you more battery setup options. You mentioned using a 12 volt SLA battery so you'd be fine. 12 volts is the sweet spot for 700 sized motors in this boat IMO.
Old 07-09-2013, 08:39 PM
  #4666
deep sky
hey df you dident tell me how you liked your escs you got the 40s i got the 30s as im still waiting on batterys
Old 07-09-2013, 08:44 PM
  #4667
dauntlessfan
Deep the ESCs I got are great. Easy to connect and calibrate, run cool to the touch, waterproof (my toddler poured a cup of water over one of them and it still works fine so I've tested the claim). So far so good!
Old 07-09-2013, 08:56 PM
  #4668
deep sky
great i have set mine up and run them on 9.6 they seem to work great the only thing i need to do is trim out the motors as one does not start at the same time the other does not by much ill play with that on sea trials when my batterys finely get here
Old 07-10-2013, 03:14 AM
  #4669
rthalls
My Feedback: (63)
thanks that help me
Old 07-10-2013, 05:49 AM
  #4670
rthalls
My Feedback: (63)
when using two speed controls , do you Y harness to the thro. stick of the RX ?
Old 07-11-2013, 02:27 AM
  #4671
Hydro Junkie
Now that depends on your radio. Some you will have to, others you can use separate channels. If you're going to use two channels for the throttles, a twin stick radio would be the better choise
Old 07-11-2013, 03:17 AM
  #4672
rthalls
My Feedback: (63)
it will be a 9ch - my flying radio
Old 07-14-2013, 04:06 PM
  #4673
wagonman2
WOW I just got the hull painted the way I wanted. Been a long journey to get to this point but I love every minute working on her.Lets see if I can post a picture.
Old 07-15-2013, 05:58 AM
  #4674
rblubaugh
wagonman2,
The finish looks AMAZING!  I could almost see my reflection.[X(]
Bob
Old 07-15-2013, 07:30 AM
  #4675
kokaneezer
kokaneezer's Avatar
Hi Wagonman- Boat looks fantastic! Was wondering what you were up to.
Steve
