Go Back  RCU Forums > RC Boats > RC Scale Boating
 1/8" to 3 mm coupling. Where? >
RC Scale Boating Enjoy rc scale boating? Talk about it here.
Old 01-01-2009 | 09:56 AM
cyclops2's Avatar
Default 1/8" to 3 mm coupling. Where?
Any suppliers out there ?
Rich
Old 01-01-2009 | 04:29 PM
rye
My Feedback: (10)
Default RE: 1/8" to 3 mm coupling. Where?
hi
try these guys you can order any size combination of sizes rye
http://www.harbormodels.com/site08/m...propulsion.htm
Old 01-01-2009 | 09:21 PM
I made my own by using the Dumas dog bone and brass coupling. Just drill one to the size needed.
dan
Old 01-02-2009 | 12:29 PM
cyclops2's Avatar
I goofed. It needs to be a 1 piece unit to connect a 3 MM shaft to a 1/8" shaft.
Old 09-25-2011 | 08:16 PM
Default RE: 1/8
Cool, use the Dumas dog bone and brass.
However, usually this type setscrew shaft coupling have to be customized. like below coupling:
<a href="http://www.fscoupling.com/18-inch-to-3mm-helical-set-screw-coupling-18x3mm-cnc-motor-shaft-coupler-diameter-16mm-length-23mmneed-customized-p-218.html">1/8"x3mm coupling
</a>just as you say, it have to be two bore to connect the each side. one bore is not useful.
-luso
Old 09-26-2011 | 08:55 AM
blizard05's Avatar
Default RE: 1/8
ORIGINAL: cyclops2
Rich
Try OSE- off shore electrics
