Dumas 20th scale pt hull correction
If I correct the Dumas 20th scale pt boat hull using the correction from Mosquito Boat? Will the hull be correct? I am told the deck on the Dumas boat dips down in the front to much. But to correct this I would have to raise the front of the deck by extending the sides up? I guess? Would this not also widen the hull at the front which flares out . Thanks, Randy.
RE: Dumas 20th scale pt hull correction
Randy,
Just follow the instructions given and you will be fine. Pete |
Thank you Subsinker, I will trust your words.
| All times are GMT -8. The time now is 01:38 AM. |
