Go Back  RCU Forums > RC Boats > RC Submarines
 water jet help please... >
RC Submarines RC submarine discussions.
Old 03-13-2005 | 09:54 AM
Default water jet help please...
hi all
can some kind soul tell me how to install and get up and running a water jet system..i,ve completed a robbe u47 sub.. and nearly finished a engel nautilus but my next project i want to install a water jet system but this is totally new to me..all and any info would be greatly appreciated like what system to use etc....
many thx
theraven
Old 03-13-2005 | 04:05 PM
Captain Nemo12's Avatar
Default RE: water jet help please...
Depend what you mean by "water jet" do you mean the kind you would install inside a sub to squirt water out at people (not a really nice thing to do!)? Or the kind used as a propulsion system? Bilge pumps and other types of pumps can be installed on a sub to give it propulsion.
Old 03-13-2005 | 04:18 PM
thx for reply m8
not the water pistol type even though that would be fun!!!propulsion to power a sub along and steering the thing as well..
cheers
Old 03-13-2005 | 06:16 PM
Check this out: http://captainnemo12.tripod.com/id29.html
Old 03-13-2005 | 09:34 PM
hope this helps
http://www.ajhobby.com/product.asp?pid=2253
Old 03-13-2005 | 10:28 PM
Umi_Ryuzuki's Avatar
In either case of the previous suggestions, I have reservations that they will be powerful enough as the main source of propulsion for a boat or submarine.
While the Graupner bow thruster is a bit overpowered as a thruster. I don't believe the propellers were designed for high powered thrust.
Actual jet pumps may be adaptable to your application by extending the shaft connection into a WTC. Since the submarine is below the water surface, jet pumps should not have any trouble with water intake.
Graupner Jet drives from Hobby Lobby
http://www.hobby-lobby.com/jetdrives.htm
KMB jet drives
http://www.jet-drive.de/
MHZ >product>drives>jet (probably a bit high powered)
http://www.mhz-engines.com/
Swashdrives, (also high power)
http://www.swashdrive.com.au/
http://www.swashdrive.com.au/phpBB2/index.php
Old 03-14-2005 | 02:00 PM
many thx for replys lads
will have a good lookat the sites as anyone done a steerable water jet system ?
many thx
