micro submarine
I have one of these subs, bought one from RadioShack two years ago. The sub itself is 2-channel controlled, that means that it can only dive forward and can't run straight. The controller itself has all teh standard, directional controls you'd find on a 2-channel radio excepth there is a "super-dive" button located on top of the transmitter case (not sure if this will make the sub 3-channels) that will make the motors turn and dive the sub faster. After a few runs I noticed that the sub's hull has cracked, this was fixed using CA glue. Also, the O-rings that seal the hull often tends to roll out after a few times when you pull open the rear hull cap. Aprt from that it was fun to play with in the kitchen sink for the first time
can anyone tell me what this is? http://cgi.ebay.com/Fast-Attack-AWES...QQcmdZViewItem i know but i want to know if you know
here's a copy of the sea scout but a lot cheaper http://cgi.ebay.com/WOW-Remote-Contr...QQcmdZViewItem the guy is selling them like crazy
ORIGINAL: HelioBreaker
CA
doh!! i would nver buy that!!!! i was just seeing if you guys know what it was. and is the hobbico sea scout any good i was thinking about geting one or a copy of one off ebay
