How could i seal the drive shaft so it want leak
I am trying to figure out what would be the best way to seal a shaft so it want leak, I thought about a nibble with a hole drilled through the center of the cab and then put the shaft in and pack the nibble with a greased string, useing it as packing. i am not sure if it will work, But if yall have a better idea on that or somthing different, please explain it to me EE Jason
RE: How could i seal the drive shaft so it want leak
It's simple Jason. You just need to go here and buy some sub tech seals from Mike. They are all I use and on my 10 plus subs I've never had a leak.
http://www.mikessubworks.com/page1.html
Just look for seals. You don't need the stuffing boxes really. The push rods seals alone work great. Hope that helps you.
Steve
Steve
