Go Back  RCU Forums > RC Boats > RC Submarines
 submarine help >
submarine help
RC Submarines RC submarine discussions.
submarine help
Old 05-04-2007 | 06:29 AM
Default submarine help
hello,
i am sorta new to rc submarining i am looking at either th gato class or the sea wolf modles could any one tell me what all i would need to conve them into a rc subamrine all help is appriciated also what is the difference between static diving and dynamic diving[sm=teeth_smile.gif]
Old 05-04-2007 | 02:03 PM
Default RE: submarine help
Hi there dynamic diving is where you use the subs forward motion and dive plains to dive and then when u reduce speed to surface a static diver is where the seb has ballast tanks on board and can pump water in and pump water out making it dive on the spot.
You would need
WTC ( WATER TIGHT CONTAINER)
Ballast tank and pump and esc to controal the pump (OPTIONAL)
3/4ch radio pack ( 3 for dynamic 4 for static diving)
servos ( 4 the RUDDER + DIVEPLAINS)
Speed controaller (recommend Msonik ESC)
Motor + Motor > Shaft connecter
Battery pack and charger
Prop shaft
Prop
Rudder, Diveplains,and all things to link dive planes and rudder to servo.
I dont think ive missed anything out!
Good Luck
Jonjoe
Old 05-04-2007 | 04:41 PM
thanks for the help jonjoe do you know out of those models i listed would be the best to start of with. [sm=regular_smile.gif] also can you tell me an aproximate price for all of the items i would need for a static diver thanks agian
lts11179
Old 05-05-2007 | 10:15 AM
subsinker's Avatar
My Feedback: (61)
Hi,
If you're new to the submarine segment I would not recommend a static diving boat. Very expensive and sometimes very complicated. However, if you are dead set on one you can expect to shell out $1,000.00 or more by the time you purchase everything. I have seen advertisements from a company called North Seas Fleet, in the UK that produces many types of static & dynamic type subs. I personally have never seen them so maybe someone else can chime in about them. They seem to be very reasonably priced. Dave Manley, the owner of Small World Models, makes probably one of the nicest pre-fabbed kits available with his Blueback submarine. Excellent starter kit. I believe the boat runs around $800.00 but the beauty of it is that you can have a static boat built in no time and the USS Blueback is a very sexy machine. A dynamic boat will set you back far less. Dumas makes a dynamic Gato class boat for under $200.00 Add in a radio & basic equipment (pitch controlller, fail safe) and you probably top out at around $500.00 more or less. Another advantage to starting simple is that you are less likely to get frustrated and quit. Also, if you lose the boat in the depths, you aren't out so much (yes, it does happen)
Hope this helps,
Pete
Old 05-05-2007 | 10:02 PM
thanks pete i cant shell out 800 dollars now so i will go with a dynamic diving sub did you mean dumas bluefish or akula or the revell gato class modle also do you know of any places i could order the things that i need for the sub thanks again for all the help
Laren
