RC Submarines RC submarine discussions.
PVC
Old 05-31-2007 | 11:17 PM
Default PVC
anyone have any ideas on how to make a scrachbuilt submarine out of pvc piping
(not like those ROVs) but as only useing one pvc pipe as the hull
Old 06-01-2007 | 05:49 AM
Default RE: PVC
YEP just made a akula out of Pvc pipe use the pipe as the main bit for your hull then construct the Bow and stern how you would like! ( normaly out of foam that you fiberglass over)
Always here to help
Jonjoe
Old 06-02-2007 | 05:17 PM
Default RE: PVC
hey thanks alot ive been at this for ever and where did you get the syrofoam at a store or some you found? and do you sand the syrofoam down? one more thing wut do you need to fiberglass it?
Old 06-21-2007 | 08:49 PM
Default RE: PVC
hi,guys
i try to make my first WTC,so i make this for sample,do have any suggestion for this is this the correct way? if yes i will make my first WTC
i hope can get the size for the wtc and end caps,i you have it also the pic
thanks
ID:	708505   Click image for larger version
ID:	708506   Click image for larger version
ID:	708507   Click image for larger version
ID:	708508   Click image for larger version
Old 06-22-2007 | 10:11 AM
Captain Nemo12's Avatar
Default RE: PVC
Nice work there!
Did you cast your endcaps from resin?
Old 06-22-2007 | 07:58 PM
Default RE: PVC
the end caps made from teflon,they sell it here with variant diameters 1-5 inch,so just choose the diameter and how thick we want they just cut it off and selling by KG not PCS,
i just make place for seal,and hole cup inside!
do u think teflon or plastic better for WTC end caps?
ID:	708990   Click image for larger version
Old 06-22-2007 | 09:24 PM
Default RE: PVC
Cool, I drew up plans for a los angelas class sub
made out of PVC pipeing. By the way, how did you do the clear
plastic? did you buy it that way or cast it on your own?
And I have no idea about which cap is better. As long as
water stays out, it's fine.
Old 06-23-2007 | 03:06 AM
Default RE: PVC
FOR THE PIPE ITS ACRYLIC 2 INCH I BUY,IN USD AROUND 25 USD FOR 2 METERS BUT,3 INCH MUCH MORE EXPENSIVE 3 TIMES THE PRICES,TODAY I ASK MY EMPLOYEE TO BUY DIFFERENT TYPE TO MAKE END CAPS,ITS NYLON BUT I DONT KNOW WHICH ONE STRONGER TEFLON OR NYLON! I WILL TELL U AFTER I TRY IT,BY THE WAY I JUST BUY DELTA MODEL FROM NORBERT BRUGGEN BUT I DONT KNOW HOW TO BUILD IT[]DOES ANYBODY EVER BUILD THE DELTA MODEL???PLEASE HELP
THANKS
JAN
