Im going to try another shot at subs need some info.
NY
Well last time i tried subs i could not get them to go down at all due to lack of balance(mine were dynamic subs using elevators to dive) so they were always too floaty and also my radio system would not go underwater. Sooo now ive got a 3ch system which im going to try rc subs with, ive got servos, umm an ESC for a speed 380 motor(used for planes with 7x2 props). NOw ive got some questions.
Sooo for waterproofing the shafts, if i just use like pen shafts with metal shafts, and use vaseline to waterproof it how deep could i go under. Im just going to waterproof the Rx and esc and batt in a bottle and have the wires sticking out, then i can just worry about the servos getting soaked and motor if my pen tubes dont work. Im thinking of using peanut butter jars like i did last time(more room) i will probably do 1 filled with the electronics and 1 with steering and powerplant then do 1 for the water(ballast) ill see what ive got to work with, i wish i had a better radio system that i know can go deep, all ive got is my 7ch Eclipse Hitec tx with 72mhz system for my planes. Soo im just going to use a 27mhz system for my rc sub, throttle, elevator and rudder. What is better for depth control? Front bow planes or elevators in the rear?
Thanks. HOpefully this time i can get a dive and drive around underwater. Il get videos pics etc...
AK
RE: Im going to try another shot at subs need some info.
Nogo with the 27mHz, I think. If I am correct, as I usually am, that is an aircraft channel, and you need a 52mhz, I belive it is. I had to do the same thing with my heli 4ch remote.
ORIGINAL: subcaptian
NY
I was just about to say the same thing, notice for Wally world products, they all use either 49 or 27mhz for planes or ground vehicles.
NY
Well the radio works i did a test depth and i was able to get down to at least 8in of water so i think i can go deeper. I have to work on my Peanutbutter jar waterproofing with the lid, otherwise i think im set and know what to do. Ill get some pics soon. Now the problems will be with the pushrod stuff, i heard that a tight fitting sleeve on a shaft will do the trick with some kind of lubricant.
NY
Yeah mine already acts up, ah well my sub will be a scratchbuilt soo perfection wont be required.
My radio system is for rc planes mainly but on 27mhz so ive got speed control in one direction only is that a bad thing?
PA
ORIGINAL: GreenAce92
Forward only ESCs are pretty small and cheap, though.
ORIGINAL: subsinker
Guys,
27Mhz will work but bear in mind that band is subject to interference.
Guys,
