I want to get into this
I want to make either a scale 688I, seawolf or trafalgar class, roughly 3-5ft long, now I know sheerline model submarines make a kit, but what else do I need to get hold of
I fly R/C helicopters, so know quite a bit about r/c, but I'm new to subs, and want to get into it, if someone could list the things I will need and a rough price it would be helpful thanks. |
RE: I want to get into this
Welcome to the hobby mate!
Well, the first thing you need to know is that: You cannot get a fully build sub kit for less than a hundred dollars! :D Imean, with the radio equipment and all. Maybe these things could be useful: -3 or 4 channel radio -Motors, Servos -paint, supllies. -glues -well, all the necessary you need to build an RC craft. I don't like to discuss about prices so they can vary depending on what you buy, but remember: K.I.S.S : Keep It Simple Stupid! :) |
cheers,
in the kit what do you usually get, do you get the pressure hull, ballast tanks and pumps. |
Usually, kits are furnished with the hull only, along with control surfaces and the prop (if you're lucky). You'll also need the following:
-paint, glue, resins, fibreglass matte, epoxies, fillers -minimum 4 channel radio (surface frequency) (throttle, dive planes, ballast system, rudder) -speed controller -failsafe system (for when, not if you ever lose signal) -automatic pitch controller (highly recommended) -battery eliminator / voltage regulator (highly recommended, especially for 12V systems) I've got some info on my site (www.rc-sub.com), and be sure to check the SubCommittee (www.subcommittee.com). You can email me at [email protected] if you have any specific questions. I'd be happy to help you out. |
| All times are GMT -8. The time now is 08:28 PM. |
