Submarines
How do you see them. Dont they go under water.
RE: Submarines
In a pool its not hard to see them. In a pond you could just go periscope depth and use that to track it, or if its clear enough you can go a little deeper. You could also trail a little float so that you can't get lost. But losing sight is always a danger if all you want to do is go deeper. Then you can lose signal or get stuck anyway.
RE: Submarines
If you can't see your submarine at all, after it dives, that body of water will be too poluted for you, for your dog and definitely your submarine ! :) :) :)
RE: Submarines
Thats why I run at the cristal clear springs hear in beutyfull Florida!
Dave |
RE: Submarines
1 Attachment(s)
I also heard that BP likes the Florida water so much that they started to play their remote submarines there :D
RE: Submarines
Ya as long as they keep it that way!
RE: Submarines
But instead of toy torpedoes, their submarines have drills on them :D:D:D:D
RE: Submarines
can you do tricks with subs?
RE: Submarines
ORIGINAL: wobblewobble can you do tricks with subs? Dan |
RE: Submarines
1 Attachment(s)
Definitely, besides roedj's own favourite ' disappearing trick ' which his submarine run away on its own like my teenager daughters :D, you can modify its diving planes to be ailerons to do what planes can do. The physics of water is similar to air although water has much higher viscosity and resistance.
RE: Submarines
Yes like this great sub!
<embed width="600" height="361" type="application/x-shockwave-flash" allowFullscreen="true" allowNetworking="all" wmode="transparent" src="http://static.photobucket.com/player.swf" flashvars="file=http%3A%2F%2Fvid82.photobucket.com %2Falbums%2Fj278%2FDavidSantivanez%2Fdevilsden1-20-08051.mp4"> |
RE: Submarines
RE: Submarines
RE: Submarines
Or like these crazy Japanese hobby subs ... http://www.youtube.com/watch?v=m2FqpaXLgeA
RE: Submarines
Can they 3d?
| All times are GMT -8. The time now is 04:57 AM. |
