Tamiya Panther Hull
RI
Tamiya Panther Hull
This is my first upolad of photos so please bear with me? The Tamiya Panther Hull has 4 slots to accomodate the two motor frames and they supply a piece of metal tape to cover them fromt tho outside ahich is not of the correct size and will leave humps in it from the motor frame. The photos show in succession the stock hull, hull with motor frames protruding, a little grinding or filing is necessary to remove some of the excess frame metal marked in black. Another photo shows the K&S aluminum plate and the last photo shows the finished plate in place on the hull.
