Sherman 3 piece trans cover
RE: Sherman 3 piece trans cover
ORIGINAL: yellowshaker
Well guys, I am inquiring again. This time I am in search of the trans cover in the picture below. I know I have seens some one build this model before and I cannot locate the thread now.
About 15 years ago I attempted to convert one of the original Shermans to a VVSS with a three piece tranny cover. It had the old clutch type gearbox. It isn't perfect, but it made me happy. I made the tranny cover out of some PVC pipe couplings and Evergreen plastic and body putty and a casting of the bolt line at the top of the cover. I had to grind some of the tranny housing off to make it fit. A pencil points to the area removed in one of the photos. The tranny cover in the photo of the M3 Lee was a total catastrophe as far as making it work for R/C and it is a thick lump of resin on the inside, and it remains a static model.
I don't know if this helps you out in any way, but it's all I have to offer based on my past efforts. Good luck with your search on this.
I was considing the same for my early IDF 75mm Sherman (IDF M-3) , and it looks as if we are going to have to scratch the bolt seams and make the 3 piece our selves.[] Like the IDF turrets, lots of work, but when it's all done, it's worth the effort.
Wow! thanks alot for the input guys. Rex, that is great work! I'd be happy too! I guess I can always try scratching it if I want one that bad huh?
I was kinda embarrassed to show the inside of that tranny cover.......It's really rough and crudely done, but I always tell myself, "If I can't see it when it's finished, it doesn't matter". I'm lazy about interior details. Whenever I scratch something, I always end up thinking........."Gee, I coulda done that better.......or differently". But I rarely end up doing a second (improved) copy with fewer mistakes. I would be happy to find out that somebody looked at my stuff and thought of a better, cheaper, faster, easier way to do some project they were working on. I have gotten a bunch of good ideas from the postings on this forum. I can't count the number of times I have seen some great way to do something and thought to myself, "Why the heck didn't I think of that"?
Rex
AB, CANADA
Gears are always turning. I have seen many things on this forum develop into somethng more then they started. I remember when Darkith first threw his ideas about the DBC on here.
The three piece tranny is one I want to soon try, so I will be refering to this. My next Sherman is going to be an early 75 mm one
A can of black flat paint will fix up the backside of this piece if it bothers you at all, but honestly I bet most stuff that you cannot see does not get the same treatment as the frontside or topside stuff..
Dan
Dan
Well, I do appreciate the help. I agree that most of the things we want to build ormodify can be done thruogh the shared ideas here.
I did find the thread on the early trans cover. It appears it was bought from Tiff Williams a few years ago. Sooo, anyone know who that is???
http://web.mac.com/ethandunsford/DAK...allery.html#66
