 Left Stick Drive Servo Elevation >
Old 12-05-2010 | 03:37 PM
Default Left Stick Drive Servo Elevation
Has anyone who uses the left stick on their Tx's to do all the driving of the Tamiya tanks ever do a servo elevation mod, and how did you wire it all up since the third channel is not used for elevation.
Old 12-11-2010 | 03:36 PM
Default RE: Left Stick Drive Servo Elevation
Well, it appears that not many do it this way. No worries, I was able to find out that the Dionysus camera positioner i am using is no good. the servo works with the wiring info from the HEAT site. However, I am not completely happy with the operational sequence of this setup. Now this may be due to the fact that I am hooked directly too the servo until i get a new positioner, but It is very hard to control the MG and Main gun functions while trying to raise or lower the gun. <div> Again this may have something to due with needing the servo slowed down, and i wont know until i get the new part. </div><div> After all this, I still like the HL elevation unit the best. To fit a small enough servo in the Pershing turret you must use a micro. One of these with enough torque to raise the gun is somewhat costly and as I said, I am not completely happy with the results anyway. May just need some more fine tuning.</div>
Old 12-11-2010 | 09:11 PM
ksoc's Avatar
I've done the conversion on both my Tamiya Tiger and Pershing per the HEAT article and using the Dioysus Camera Positioner.. What radio are you using? I use Spektrums and have the gun tied to one of the switch on top. I will try to post some picts tomorrow.
Old 12-11-2010 | 09:15 PM
I am using one of the new Hobby people Areosport 5's. It's a great radio but like i said the issue i'm having is due to no speed control of the servo at the moment until i get a new camera positioner. the one i have is an ealy version. the new ones are capable of handling more input voltage which i beleive was the problem. The first gen ones would just cook off from the higher voltage needed to run the High torque servos.
