HL tank question
HL tank question
hey guys, i got my walker bulldog today. i was wondering if anyone could tell me how long the battery takes to charge. i was hoping for a led indicator but i guess not.
RE: HL tank question
ORIGINAL: diabolic-mind
Q: How long should I charge mybattery packwith the supplied wall charger?
A: Add 15% to the battery pack's rated capacity, then divide the sum by the charger's output amperage to get charge time. For example, if you have a 2000mAh battery pack and a 400mAh charger, then the charge time is (2000 + 0.15*2000)/400 = 5.75 hours or 5 hours 45 minutes. If your charger's output is 500mAh, then the charge time is 4.6 hours or 4 hours 36 minutes. However, you can charge the battery pack for 5 hours initially.
<fieldset><legend accesskey="I">Attachments</legend>
http://www.rcuniverse.com/highslide/graphics/zoomin.cur), pointer; outline-style: none; outline-width: initial; outline-color: initial; "> Click for fullsize |
</fieldset>
lol you just lost me, i got the stock charger and stock battery. i know off hand the battery is 1700mah. not sure of the charger, but there both stock
5 hours for the first time, 4 hours or so after that. If you get serious with this hobby, should you find that you like it, you'll quickly dump the charger and those batteries and get a real Peak Charger and some 3600 mah or bigger batteries.
There's probably lots of other good ones out there but I have this one;
http://www.all-battery.com/smartuniv...uresensor.aspx
It will charge the stock battery in approx. an hour.
Here's a very good deal on better batteries at a very reasonabloe price. .
http://cgi.ebay.com/4-pcs-7-2V-4300m.../170484626250?
