HL Tiger ???
HL Tiger ???
Took a little break from the KT and was looking at my HL Tiger, I got the mato metal wheels,tires arms and springs. Was wondering if you use the screw axles over again and have to tap them int the arm or are there other axle screws???
Ron
Ron
RE: HL Tiger ???
When Iinstalled my Mato metal swing arms, Ijust used the old axle bolts. Be careful though, ithe holes in the arms are not tapped and you may have to force the screws a little which means you can easily strip the bolts's drive hex and or break the threaded end off the bolt.
