HL plastic
I have used Plastruct Bondene successfully with HL plastics before - the label doesn't say what's in it, but it smells like some other methyl ethyl ketone (MEK) based solvents I have used in the past. Pro Weld makes similar claims about its uses, so you should be ok with that.
HTH,
Mart
HTH,
Mart
I've done a great many conversions with HL tanks and CA glue does fine. For stubborn or hard to line up parts, you can use a drop and hit with Zip Kicker accelerator to lock it in place then add a couple drops to adjacent areas for strength.
