help with panther suspension
i just got the heng long panther, but the suspension for each wheel is still stiff, is there a way to get them looser, so they move up and down easier
AB, CANADA
RE: help with panther suspension
You have to pop off the hubcaps and back out the screws and remove the wheels. You will then find an alan key head axle bolt. Just slightly back this off until the suspension moves freely. You might want to remove the axle bolt completely and then use some blue thread lock on the threads to preven the axle bolt from backing out.
