HL / TAMIYA Electrical help
NY
This week I started to convert my stock HL tiger I by replacing the electronics with Tamiya electronics that were removed from my HL Jadgpanther. with that done I also replaced the stock gun barrel,muzzle break and mantel with ones that i had purchased awhile back along with using the jadgpanther barrel recoil unit , and the guns elevation units from the kv1 both HL and a little modification the barrel and the recoil unit combo should work out fine. Now the hook up ,that is were I could use some advice in this area. if someone has done this mod using tamiya/Hl recoil unit can you answer this . When I tested the guns rotation and the elevation using the tigers original gun and elevation that was a simple hook-up ,but now there is the recoil weiring. Thanks chief
NY
RE: HL / TAMIYA Electrical help
Thanks I'm aware of that, I had remembered that after i posted this. with that said the wires are blue green and white. now would you know were and witch one of these wires coming from the MFU unit will go to on the recoil unit, The tamiya recoil unit is wired as green to + post to motor, blue wire goes to a limit switch, white wire goes to the - post on the motor and then also goes to the limit switch. I think the limit switch is wired in the normally open position. thanks for your reply
close to the orange plug is the 3 pin conecter the pin closest to the orange plug is pin 1 the next pin is 2 and then 3 pin1 is white triger pin2 is green + pin 3 is blue-
NY
I thank you for all your help,this is what i see when looking at when the dmd unit,were everything is legible. to the left of the operation indicator light. is the 3pins for the three pin plug marked cn6 recoil. what I have is from rt to left is blue,green,white. is this what you have. the order in which you posted the blue and white wires are opposite of mine.
