10 speed system and 3.1
These are specs of a Panther model for sale online (New Kit)
This the Heng long Panther G Smoke & Sound with the latest RX-18 board RC Tank. This terro of WWII comes in Camo paint job or grey. This tank is a full Function Radio Controlled; Turret Cannon Moves Up and Down; Move All Directions; Cannon recoil and Flash! Realistic Suspension System; Realsistic Commander is Equipped; 7.2v Recharged Battery; Tank Transmitter; Excellent Maneuvering Performance; <u>10-Speed System</u>;Pre-Painted Body; Approx Operating Time 30 Minutes; Operating Passenger Included; Factory Assembled - READY TO RUN; Scale 1:16
Notice in the specs it says: 10-Speed System
Can someone tell me if this 10-Speed system is the same as having the 3.1 gears installed or is this something completly different? Are they refering to the electronics instead of actual gears controling the speed?
I'm trying to decide to either order one with this system or one with the new version 2 - 3.1 gears or with both the 10 speed and 3.1 gears.
Thanks in advance,
~A~
Thanks in advance,
~A~
FL
They're referring to electronics......speed proportion in 10 steps instead of the previous 2.
Where are you seeing that you can order a HL with the new revision 2 Mato Gears?!
ORIGINAL: MassiveOverkill
So what would be better? the 10 speed or the 3.1 gears?
They all come with 10 speed electronics now. You have to buy the 3:1 gearboxes separately if you want slower scale speed with more torque
ORIGINAL: smokinbarracuda
I don't know if any of their IR tanks are this way but just the Airsoft models are (the 3 I looked at)
Now I'm starting to see why prices are fluctuating on the same kit sold by many different companies. These tanks have several different kinds of options right out of the box.
If you notice and after further investigation of the HobbyKing tanks for around 40 to 60 bucks... They are HL tanks but they do not have smoke or sounds and do not have metal tracks or metal parts at all, they are just a basic tank and I would be willing to bet they have plastic gears and not metal but Idon't know that for sure so this would be understandable to be so cheap as around 50 bucks But at the same time would be great if your going to update one with ELMODand other items as well. Makes for a good customizing platform.
Thanks for your replies.
~A~
Well from what I've seen I'll list the different options available:
1 - Non smoke n sound (rx13)1 or 2 speed forwards and backwards. All plastic tracks and gearboxes
2 - Smoke n sound (rx14 or rx18) 10 speed forwards and backwards. All plastic tracks and gearboxes unless specified as metal.
As far as I'm aware none come with the 3:1 boxes installed but some places do install the normal metal boxes, tracks and sprockets for you but at a much higher cost. I also assume its the same for the infra red series as the airsoft.
Unless you're buying a custom tank, no one sells one with the 3:1 gearboxes installed. That has to be purchased and installed separately. Generally, you buy the SNS tank for the proportional speed if you're getting 3:1 gearboxes.
Philipat,
what about these models? Look at their descriptions as they are listing the 3.1 gears. It appears they are installed.
http://www.tankzone.co.uk/cart/henglong.htm
Here's one of the ads:
<font size="2" face="Arial, Helvetica, sans-serif"><a href="http://www.tankzone.co.uk/images/hl/sp/T1C.jpg"><font size="1" face="Verdana, Arial, Helvetica, sans-serif">1/16 Early Production Tiger 1
in Tiki Eastern Front Finish</font></a><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font color="#666600">
Smoke & Sound System</font></font></font></font></font></font></font><font size="1" face="Verdana, Arial, Helvetica, sans-serif">
</font></font><font color="#666600">New RX-18 Multi-function Unit
Custom 'Tiki' Das Reich Scheme</font><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font color="#666600">
<font color="#000066">IR Battle System installed</font></font></font></font></font></font></font></font></font><font color="#000066">
</font></font><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1"><font face="Arial, Helvetica, sans-serif"><font face="Arial, Helvetica, sans-serif"><font size="1"><font size="1"><font face="Arial, Helvetica, sans-serif"><font face="Arial, Helvetica, sans-serif"><font size="1"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1"><font face="Arial, Helvetica, sans-serif"><font face="Arial, Helvetica, sans-serif"><font size="1"><font size="1"><font face="Arial, Helvetica, sans-serif"><font face="Arial, Helvetica, sans-serif"><font size="1"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif">New Metal 3:1 Gearboxes</font></font></font><font color="#666600">
</font><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif">Metal Lower Chassis</font></font></font></font></font></font></font></font></font></font></font></font></font></font></font><font color="#000066"> </font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font><font color="#666600">
</font></font></font></font></font></font><font size="2" face="Arial, Helvetica, sans-serif"><font size="1"><font face="Arial, Helvetica, sans-serif"><font face="Arial, Helvetica, sans-serif"><font size="1"><font size="1"><font face="Arial, Helvetica, sans-serif"><font face="Arial, Helvetica, sans-serif"><font size="1"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1"><font face="Arial, Helvetica, sans-serif"><font face="Arial, Helvetica, sans-serif"><font size="1"><font size="1"><font face="Arial, Helvetica, sans-serif"><font face="Arial, Helvetica, sans-serif"><font size="1"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif" color="#003300"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font color="#666600">Higher Capacity Ni-Mh Battery</font></font><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font color="#666600">
Opening Front Hatches</font></font></font></font></font></font></font></font><font color="#666600">
with Plastic Tracks</font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font><font size="1" face="Verdana, Arial, Helvetica, sans-serif">
<font color="#333333">£189.95</font></font><font size="1" face="Verdana, Arial, Helvetica, sans-serif">
</font><font size="1"><font face="Arial, Helvetica, sans-serif"><font face="Arial, Helvetica, sans-serif"><font size="1"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><a>
</a></font></font></font></font></font></font></font></font></font><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font color="#666600">
</font></font></font></font></font></font></font></font></font></font></font><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font color="#666600">with Metal Sprockets & idlers
& High Grade Metal Tracks</font></font></font></font></font></font></font></font></font></font></font><font size="2" face="Arial, Helvetica, sans-serif">
<font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font color="#333333">£249.95</font></font></font>
<font size="1"><font face="Arial, Helvetica, sans-serif"><font face="Arial, Helvetica, sans-serif"><font size="1"><font size="1"><font face="Arial, Helvetica, sans-serif"><font face="Arial, Helvetica, sans-serif"><font size="1"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1"><font face="Arial, Helvetica, sans-serif"><font face="Arial, Helvetica, sans-serif"><font size="1"><font size="1"><font face="Arial, Helvetica, sans-serif"><font face="Arial, Helvetica, sans-serif"><font size="1"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><a>
</a></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font>
<font size="2" face="Arial, Helvetica, sans-serif"><font size="1"><font face="Arial, Helvetica, sans-serif"><font face="Arial, Helvetica, sans-serif"><font size="1"><font size="1"><font face="Arial, Helvetica, sans-serif"><font face="Arial, Helvetica, sans-serif"><font size="1"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1"><font face="Arial, Helvetica, sans-serif"><font face="Arial, Helvetica, sans-serif"><font size="1"><font size="1"><font face="Arial, Helvetica, sans-serif"><font face="Arial, Helvetica, sans-serif"><font size="1"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif" color="#003300"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><a href="http://www.tankzone.co.uk/images/hl/sp/T1ET/T1E_YRB.jpg">1/16 Early Production Tiger 1
in 2-Tone Finish</a></font></font><font color="#666600">
</font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif" color="#003300"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font color="#666600">Smoke & Sound System</font></font></font></font></font></font></font><font size="1" face="Verdana, Arial, Helvetica, sans-serif">
</font></font><font color="#666600">New RX-18 Multi-function Unit </font><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif">
Custom 2-Tone Finish</font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif" color="#003300"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font color="#666600">
</font></font></font></font></font><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font color="#666600">Airsoft BB Gun</font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font><font color="#666600">
</font></font><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font color="#666600">New Metal 3:1 Gearboxes</font></font></font><font color="#666600">
</font><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif">Metal Lower Chassis</font></font></font></font></font></font></font></font></font></font></font></font></font></font></font><font color="#000066"> </font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font><font color="#666600">
</font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif" color="#003300"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font color="#666600">Higher Capacity Ni-Mh Battery</font></font><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font color="#666600">
with Plastic Tracks</font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif" color="#003300"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif">
<font color="#333333">£189.95</font></font></font><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><a href="http://www.tankzone.co.uk/cart/%20"><font color="#cc0000">
</font></a></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font><font size="1" face="Verdana, Arial, Helvetica, sans-serif" color="#cc0000"><font><font><font><font>Temporarily
Out of Stock</font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif" color="#003300"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif">
</font></font><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><a>Temporarily
Out of Stock</a></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font>
<a href="http://www.tankzone.co.uk/images/tam/T1/T1LD.jpg"><font size="1" face="Verdana, Arial, Helvetica, sans-serif">1/16 Late Production Tiger 1
in Yellow with Zimmerit</font></a><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font color="#666600">
</font></font><font color="#666600">New RX-18 Multi-function Unit</font></font></font></font></font></font><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font color="#666600">
Custom Weathered Finish</font></font></font></font></font></font></font></font></font></font></font></font></font></font><font color="#666600">
</font><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font color="#666600"><font color="#000066">Ultimate Sparkling Version</font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font><font color="#666600">
</font><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font color="#666600">(High Intensity Gun Flash</font></font></font></font></font></font>)<font color="#666600">
<a href="http://www.tankzone.co.uk/images/hl/sp/T1LD/T1LY.jpg"><font size="1" face="Verdana, Arial, Helvetica, sans-serif">
</font></a><font color="#ff0000"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font color="#000066">Metal Lower Chassis</font></font></font></font></font></font></font></font></font></font></font></font></font></font></font><font color="#006600"> </font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font><font color="#666600">
</font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font color="#666600">
</font></font><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font color="#666600">New Metal 3:1 Gearboxes</font><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font color="#666600">
Full length Metal Gun Barrel</font></font></font></font></font></font></font><font color="#666600">
Realistic Gun Recoil
with </font><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font color="#666600"> Metal Sprockets & Idlers</font></font></font></font></font></font></font>,
<font color="#666600">All Metal Roadwheels &
High Grade Metal Tracks</font></font></font></font></font><font size="1" face="Verdana, Arial, Helvetica, sans-serif">
<font color="#333333">£299.95</font></font></font><font size="1" face="Verdana, Arial, Helvetica, sans-serif">
<font size="1"><font face="Arial, Helvetica, sans-serif"><font face="Arial, Helvetica, sans-serif"><font size="1"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><a><font size="1">Temporarily
Out of Stock</font></a></font></font></font></font></font></font></font></font></font></font>
</a></font></font></font></font></font></font></font></font></font><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font color="#666600"></font></font></font></font></font></font></font></font></font></font></font><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font color="#666600">with Metal Sprockets & idlers
</a></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font></font><font size="2" face="Arial, Helvetica, sans-serif"><font size="1"><font face="Arial, Helvetica, sans-serif"><font face="Arial, Helvetica, sans-serif"><font size="1"><font size="1"><font face="Arial, Helvetica, sans-serif"><font face="Arial, Helvetica, sans-serif"><font size="1"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1"><font face="Arial, Helvetica, sans-serif"><font face="Arial, Helvetica, sans-serif"><font size="1"><font size="1"><font face="Arial, Helvetica, sans-serif"><font face="Arial, Helvetica, sans-serif"><font size="1"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif" color="#003300"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="1" face="Verdana, Arial, Helvetica, sans-serif"><font size="2" face="Arial, Helvetica, sans-serif"><a href="http://www.tankzone.co.uk/images/hl/sp/T1ET/T1E_YRB.jpg">1/16 Early Production Tiger 1
Those are just regular S&S Tanks that they upgrade and sell. There are no HL Tanks with factory installed 3-1 gears.</p>
However not too long ago they didn't come with metal gears which are now the standard boxes for HL so I wouldn't be surprised if we start seeing factory installed 3-1's. I would look to Matomart to confirm any factory included gear since they are the official HL suppliers for North America. If HL is building it than they will be stocking it as it comes off the factory line. </p>
Not to mention you are looking in the wrong place. That site is the MOST expensive that you could possibly buy from.
As it has been said , to tank comes with 3:1 boxes Unless they are a special edition like the ones you are looking at.
It simply does not pay to buy one of these tanks, they are not kits, with the 3:1 boxes already installed. The extra price will kill you.
They are charging you to install them plus marking the price up too boot.
ORIGINAL: Panther G
I'm thinking on going with either Matomart or Phil depending on a few other things or not.
Thanks everyone.
Have a great day!
~A~
Phil will upgrade and customize your tank for you, if you tell him what you want. Check with him for a price quote. Another option for cheaper upgrades that appear to be Asiatam but at better prices can be found from Taigen at Awesome Hobbies in Australia. Keep an eye on the shipping, though.
hgpilot</p>
Definitely go with Phil if you are in the U.S. Mato is a very good seller but the shipping is pretty expensive within the US and not to rip on their customer service but they cant match Phil's level of service since they wont do things like install your upgrades or do a full check to make sure the Tank is running as it should, or nothing is broken before it ships out to you. Maybe it doesnt matter to most people these days but dealing with a vendor 1 on 1 who obviously has a passion for the Hobby is worth more than getting the best deal and just being an account number when or if something goes south. </p>
Just my 2cents </p>
Welcome aboard bye the way
</p>
Yeah i realize that my friend. The point was that people see that site and can get very confused as to what is a normal sale and something that is a total upgraded verion with an astronomical price.
ORIGINAL: Panther G
I talked to Phil and it looks like I'll be dealing with him but Ihave to wait on some funds to arrive or sell a couple of things I don't use anymore first.
shouldn't be much longer.
Thanks to all.
~A~
DANG IHATEWAITING!!!
DANG I HATE WAITING!!!
I've been waiting for about five years to buy a Tamiya and now I have a sixth month old son, so it looks like in about 18yrs I will be getting my Pershing
wade
