 Pershing Hinges or Hingeable Grills? >
Old 04-11-2011 | 09:32 AM
Devildog0341Va's Avatar
Default Pershing Hinges or Hingeable Grills?
I am in the process of finishing my Pershing (assembley that is) and I just cant bring myself to glue the grills onto the main body. Is there anyway to make them to operate on a hinge (the way there suppose to do) or does someone make a set that are hinged or a set of hingesthat I can mount them to my pershing? If not this would be a good idea for someone to run with I just cant see glueing them down.
Thanks, Jim
Old 04-11-2011 | 02:01 PM
Default RE: Pershing Hinges or Hingeable Grills?
You pretty much need to make your own hinges. It's not that hard. Cut in between all the hinge points, then drill a small hole through all of themk and use a smal piece of track pin. works great. Did that with the hatches on my TaMato Sherman.
Old 04-11-2011 | 05:15 PM
I think I can do this. What did you use to cut between the higes with?
Thanks, Jim
